Lillee wrote:
STRIP:
So I heard that sand blast is too rough and bead blast or soda blast is better? What have others done?
How can I transport the shell around while this is happenning? I'd probably want to strip her down myself in the garage. Take subframes out, strip interior etc. How have others moved body shells? I want the whole body evenly done in same colour, under and inside.
Who can do the blasting in Sydney? any recommendations? How much does it cost?
Garnet blasting is extremely good for removing rust and bog, its quick, its cheap, its easy. Provided that the guy holding the gun isn't a total monkey (and chances are,,, he probably is a complete knuckle dragger) it "should" be fine for general paint removal.. There is absolutely nothing wrong with it provided its done correctly. If its not, then you've got problems. It does gernerate a lot of heat, so there is a lot of potential for panel destortion (if you stand there too long hammering away at one area of course), it is of course a lot more aggressive... I'm sure every one knows a guy, who has a friend, whose brothers uncles aunt's son's friend sent a car for blasting and got it back with paper thin panels.
I tend to get my stuff soda blasted, then let the guys look over it and ONLY garnet blast (bloody hell kids,
sand blast you jagon junkies!) the parts that need it.
Soda blasting is still some what new tech in this country, the Yanks have been doing it for years... but its only been available for about 10ish years here... so its still very expensive AND there are a lot of places that don't know how to use the stuff.....see, with soda, its very very fine. Its powder. So as soon as you pull the trigger, suddenly the visablity becomes zero. To combat this, a lot of places do their blasting "wet" which turns the settling powder into a paste that then works its way into all the nooks and crannies that kirby mentioned earlier.... not a good look
make sure you talk to the guys about how they run their set up and make sure they use dust extraction and not water. I use a place called "Sydney Soda Blasting" their down at Seven Hills in the industrial area. The last mini I had done cost $2600 (soda and garnet)..... HOWEVER, I have recently met a guy who owns a shop somewhere in south sydney who reckons he can do a mini for about $1800.... I have not used him, I don't know anything about his quality of work etc... but if you like I can find out his details if you like?
BODYWORK:So once it's silver metal, does the strip shop paint it over with primer or does it come to me in bare metal?
I would want to do most of the repair and prep at home over several weeks/months so will she be OK sitting in primer for some time?
Some places do and some do not prime cars after blasting. If its been soda blasted it can (no joke) sit around for months and months on end with out paint and it won't rust.. regardless of humidity.... I have a bonnet in my shed that was done 18 months ago and inspite of rain and humid crappy wether.. it has
ONLY rusted in the places that I have touched with my bare hands (must be the oil in your skin). Just ask the guys at what ever place you take it too about how they finish the job (primer or no primer).
If you use 2k epoxy primer, shouldn't be a problem. Still not really ideal to leave it sit in primer too long without paint though. If you use Acrylic primer, acrylic etch or acrylic high fill (which it doesn't sound like you will) do NOT let it sit longer than 4-5 monts or it will suck in moisture like a spounge.
RESPRAY
I am sold on 2 pack, what can I expect to pay for a final respray if I do most of the prep work myself? I've been told to pay a little extra so that the painter does the final stages themselves for the best finish. What are the stages?? bog, weld, high fill primer, guide coat, sand, primer?? wipe down?? 2 Pack?? Clear coat??
Stages are (in order) beat, weld, beat weld, bog, high fill, guide coat, prepsol, tac rag, Base, Clear.
Like someone else already said, some places will not go anywhere near you're car if you've done the prep work. I refuse(refused) to touch anyones car who's done their own prep work. Only reason is that all to often, they haven't done some thing right and the paint fries up or ends up with some kind of defect...
or...
They do a pathetic job of their prep work, and it only becomes apparent once there is paint on the car... so "
naturally" because I painted it... its my fault that they didn't feather the edges of the bog properly or the panels are all ripplely because
they didn't use a long block for sanding large flat panels... So of course being
""my"" fault, they try and rope me into re-doing their shoty prep work for free..... Sorry bucko AIN'T HAPPENING!!!!
What were the other questions?
