It is currently Mon Jul 21, 2025 11:55 pm
 Post subject: mini matic
PostPosted: Mon Oct 04, 2010 8:04 pm
hello , just brought a 68 mini matic , sort of a barn find , no rust with a blown head gasket , does anyone know if a common problem exists with auto's with oil leakage , if so where from , I am restoring it at the moment so cant get on ramps to look , is there a seal or plate that often leaks as i have heard of , once its painted will get on hoist , any input apreciated thanx
neil
Ruling the bends and bending the rules since 1959
PostPosted: Mon Oct 04, 2010 8:14 pm
I have a 998 Minimatic (but it's a 1412 manual now). I drove it about for 12 months before I made it manual.
Matics leak where manual ones do, with a couple of extra spots.
Most common are the seals on each side of the diff, and the shift cable entry at front of box. Also the big front cover gasket, if flanges have not been cleaned properly before fitting.
There is a seal behind the torque converter, it can leak too.
Note the gearbox gaskets and seals are all different to a manual Mini box (but the diff seals are same as a Cooper S).
PostPosted: Mon Oct 04, 2010 8:16 pm
Here's the best place for questions and answers
http://autominiregister.proboards.com/
There's nothing much to go wrong on an AP auto , same with any motor , its just regular maintenance
and with yours one of the cool benefits is the ability to be tow started, towed or pushed to 25kph in neutral then into 2nd and the car starts , into drive and away you go
lots of parts still available still too !
PostPosted: Mon Oct 04, 2010 8:27 pm
1st thing that goes is usually the fwd clutch, as I explained in PM.
They like regular (ie frequent) oil and filter changes.:wink:
