Rear wheel bearings https://www.ausmini.com/forums/viewtopic.php?f=2&t=66121 |
Author: | Frank Mathews [ Tue Oct 05, 2010 9:56 am ] |
Post subject: | Rear wheel bearings |
Just fitted a set of tapered rear wheel bearings and was wondering, how tight do you do up the hub nut? I've been told that they should be done up tight then backed off about one castelation on the nut. Does this sound about right? Any help would be great. Thanks, Frank. ![]() |
Author: | sgc [ Tue Oct 05, 2010 10:08 am ] |
The book says 60 ft-lb and then align to the next split-pin hole (i.e. don't back off). But since the rear stub axles are fixed and don't transmit any torque, some people just do them up tight-ish and fit the pin. Personally, after going through several sets of tapered bearings by not setting the preload correctly, I now make sure the preload is correct and torque up as per the book. |
Author: | Lillee [ Tue Oct 05, 2010 10:08 am ] |
No do them up tight to the next castelation. You really need a torque wrench as how tight is tight? It's not something you want to get wrong... 60ft/lbs is what you need to do them up to, that is pretty tight. |
Author: | TheMiniMan [ Tue Oct 05, 2010 11:59 am ] |
There`s 2 ways to set tapered rear wheel brgs with the center spacer or without With the spacer you tighten the nut up tight & to the next castelation for the split pin,, BUT!!!! that is only """"IF""" the spacer is the correct thickness---> too thin & you will over load the pre-load & pre-mature wear is imminent,,, too wide & wear is also pre-mature because they are running loose,,, so the thickness of the spacer is crucial if running without the spacer then nip the bearing up till the brg is "Firm-ish) & then back it off a tad till it turns free but with no play,,, slip the split pin in & you`re away,,,, as per Holden front wheel brgs |
Author: | GT mowog [ Tue Oct 05, 2010 12:44 pm ] |
With the latest tapered rollers that have half a spacer on each bearing, the pre-load is too high. I put a single 0.005" shim between them and it's right then. |
Author: | Moriarty [ Tue Oct 05, 2010 12:57 pm ] |
So basically avoid Minis then...? ![]() |
Author: | MINImal effort [ Tue Oct 05, 2010 4:10 pm ] |
.... and I presume you are already aware the LEFT side nut has an opposite thread direction to normal just to confuse matters..... (eg instead of lefty loosey and righty tighty * - left is tighten and right loosen) (though when I came to service my race mini found that it had been modified and fitted with a right hand axle stub so was "normal" ![]() ![]() * (learnt that at Circ de Solei ![]() |
