It is currently Sat Jul 19, 2025 12:28 am
 Post subject: Front Mount Rad.
PostPosted: Tue Oct 05, 2010 6:39 pm
what do you think of this guys.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 1179wt_941
reckon it would fit & would it work?
I was thinking of relocating to a front mount, ditching the yellow fan but using the manual water pump while using a thermo fan instead.
if i run some pipe to that would it be to long for the water to travel?
and if the pipes are a bit thinner would it restrict it?
im trying to find out the in-outlet size in mm but all I have is 3/4
anyone know the mini's pipe size.
PostPosted: Tue Oct 05, 2010 6:43 pm
This listing () has been removed, or this item is not available.
•Please check that you've entered the correct item number
•Listings that have ended 90 or more days ago will not be available for viewing.
Now i have no idea what your on about :? :lol:
PostPosted: Tue Oct 05, 2010 6:48 pm
fixed link :)
PostPosted: Tue Oct 05, 2010 6:55 pm
Looks the Bis NG but what are you trying to cool a V8, are you getting overheating probs?? Nice but i reckon more trouble than its worth, just my opinion tho
PostPosted: Tue Oct 05, 2010 6:58 pm
The ~97 on Mini's were fitted with a front radiator. It is a fair bit of work to fit one, but would be less than that one.
But, why change?
PostPosted: Tue Oct 05, 2010 6:59 pm
cant offer any advice ther than outlet is ~19mm (1 inch = 25.4mm so 0.75x25.4 = 19.05)
I have a problem.. apparently
PostPosted: Tue Oct 05, 2010 7:05 pm
But, why change?
looks pretty simple. mount, run new pipes? have a switch to turn the fan on?
I could buy a MPi rad even Easier?
I'm still running a mechanical water pump though.
i want to move my aircon condensor where the rad would be.
neater looking set up & re pipe my aircon is all.
little bit of shifting around really.
PostPosted: Tue Oct 05, 2010 7:09 pm
Where are you going to move the compressor too?
I'd leave the regular radiator in. Ditch the fan and put an electric one in behind it if you must, but nothing wrong with mechanical fans.
:D
PostPosted: Tue Oct 05, 2010 7:12 pm
:D
move the condensor where the rad was* will fit i checked & run some new pipes.
then use a front mount Rad MPi with a overflow tank with a pressure cap with a electric fan.
that was my thinkings lol
PostPosted: Tue Oct 05, 2010 7:15 pm
My car runs too cold in winter as it is... People who have problems with cooling need to redistrip their blocks to get the rust out, after replacing their radiator with a new one... JMHO
PRistic runs a very hot 1100 turbo and doesn't have a need for a front mounted radiator, not sure why everyone else needs one? :)
PostPosted: Tue Oct 05, 2010 7:33 pm
NG wrote:
move the compressor where the rad was* will fit i checked & run some new pipes.then use a front mount Rad MPi with a overflow tank with a pressure cap with a electric fan.
So in other words, this:
Looks crap. Looks even more cluttered than what you're trying to ditch.
You have to keep the compressor on the engine but have it backwards to the mounts will be a bitch, and if you haven't hacked you radiator shroud out it'll have to go.
Will make engine in / out harder.
PostPosted: Tue Oct 05, 2010 7:37 pm
The only reason late Minis in UK got the front rad, was to meet drive-by noise regulations.
Waste of time doing it for any other reason. If you do, your carby is then getting warm air not cool = less HP.
PostPosted: Tue Oct 05, 2010 8:03 pm
if you do decide to purchase check postage to Aus i found it very dear last time i got some chev stuff sent over(postage more than parts :oops: )wife not happy :evil:
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Tue Oct 05, 2010 8:29 pm
Judging by this i reckon you should leave your rad where it is and just go and polish something :lol:
PostPosted: Tue Oct 05, 2010 9:12 pm
So NG, do you intend to move the "compressor" or the "condenser"? condenser being the air-con's little radiator. Moving all this stuff around is in my opinion too much hassle for too little gain.
If you really want space that bad, just ditch the a/c all together
