Could somebody with a clubman GT or someone who may know help me with the following question.
I have been working on my 10/71 GT (alternator internally regulated)
And took me a while to get my wiper motor working as the correct wire that was to go to the motor was plugged into the double green wire (the wire was green with a black tracer).
Once that was sorted and i had everything working ( i think everything-lights, blinkers, wipers, washer motor etc) i had two wire ends left over, as shown below
Now the double wire with the black end is an active, and the wires are plain green and go down with the general wiring harness and across the front of the car and stop where you see them. (i havnt traced it right back)
The single green wire with the metal male connector runs down the wiring harness from behind the dash some where (i havnt traced it further than that) and is not an active or earth wire. It appears to have a red tracer (but is very faded/worn)
I have tried to follow the gregories wiring diagram but is very poor as it says wrong coloured wires and excludes some things that the GT has.
So can somebody tell me where they go/what they are for.
Hopefuly GT mowog, or Gavin from NZ sees this
