It is currently Tue Jul 22, 2025 2:14 am
 Post subject: heat shield
PostPosted: Sat Oct 09, 2010 5:22 pm
Does one need to have the heat shields on twin carbs
PostPosted: Sat Oct 09, 2010 6:02 pm
Car will run without a heat shield but they serve 2 purposes-
1. They shield the float bowls from exhaust heat, which helps stop fuel vaporization when stopped.
2. If the float bowl overflows due to a needle valve/seat problem, the fuel drips on to the heat shield and (hopefully) clear of the exhaust.
