It is currently Fri Aug 01, 2025 11:26 pm
 Post subject: Help with bolt size
PostPosted: Sat Oct 09, 2010 10:53 am
Can someone tell me the size and thread of the bolts that hold this exhaust mount to the rear of the subframe.
Thanks
Steve
PostPosted: Sat Oct 09, 2010 11:06 am
Hi Steve, 5/16 unf probably about 1" long, will check.
have got heaps, let me know if you need some.
PostPosted: Sat Oct 09, 2010 11:08 am
Thanks 850 GT
PostPosted: Sat Oct 09, 2010 3:52 pm
Yeap, 5/16" UNF but I use ones 5/8" Long. Grade 5 of course :wink:
PostPosted: Sat Oct 09, 2010 9:33 pm
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... :MESELX:IT :wink:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Mon Oct 11, 2010 10:36 am
ooooo while we are on a bolt and hole thread, can anyone tell me if the screws that bolt the boot hinge to the body are the same as the ones that bolt the hinge to the boot??
PostPosted: Mon Oct 11, 2010 10:46 am
the screws have nuts on the back on the bottom part of the hinge, the top half of the hinge has studs with nuts on the back. not sure if the the threads are the same.
PostPosted: Mon Oct 11, 2010 1:26 pm
They are 1/4" UNF. It was loose screws (Pozi-drive) and nuts for the hinge to body and should have studs in the hinge to boot lid.
PostPosted: Mon Oct 11, 2010 2:29 pm
Thanks GT. One of my studs felt loose when i used one of the bolts so i wasnt sure if they were the same size. It could be one of my studs is bent.
I will further investigate but thank you.
PostPosted: Mon Oct 11, 2010 2:58 pm
(Ahhh....manners :) )
Your welcome :wink:
