Eng No. ID
https://www.ausmini.com/forums/viewtopic.php?f=2&t=66300
Author:  SuperCooper [ Wed Oct 13, 2010 8:59 pm ]
Post subject:  Eng No. ID
12YE/A/H2205
1275 Auto from............ A Moke?
Anyone? Thanks.
Author:  drmini in aust [ Wed Oct 13, 2010 9:11 pm ]
Morris 1300 automatic.
I run one (converted to manual) in my 1360. :wink:
Author:  SuperCooper [ Wed Oct 13, 2010 9:16 pm ]
Thanks Dr , the cam bearing nearest the oil pump seems to be not as wide?
What bore is your stroker? 73mm?
This block is std bore - a Virgin!
Author:  drmini in aust [ Wed Oct 13, 2010 9:20 pm ]
The rear cam bearing shell is narrow (same as a smallbore block) because the recess for the BIG automatic pump is deeper.
Using an auto block in a manual needs mods, and an oil pump spacer. Read my sticky in the mods forum.
Yep my 1412 stroker is 73mm bore. Stroke is 84.33mm.
Author:  TheMiniMan [ Wed Oct 13, 2010 9:45 pm ]
I have oil pump adaptor plates in stock
