It is currently Sat Jul 19, 2025 1:43 am
 Post subject: Extra Gauges
PostPosted: Tue Oct 12, 2010 2:49 pm
What extra gauges do people run ?
i have oil pressure gauge,what else should i use ?
have a clubman with 2 gauge dash.
PostPosted: Tue Oct 12, 2010 3:22 pm
Tacho? :lol:
PostPosted: Tue Oct 12, 2010 3:56 pm
I have a vacuum gauge!
It broke and I didn't notice. Don't get one.
PostPosted: Tue Oct 12, 2010 5:27 pm
I bought all the different gauges, spent time wiring them all up and then ripped them all out except the tacho to go back to more of an original look.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Tue Oct 12, 2010 5:36 pm
I have
Tacho, fuel, temp, oil pressure
Oil pressure doesn't work but I have a hole in my dash so what are you going to do.
I like the temp gauge as it lets you know when things are going bad in advance :)
My fuel gauge has a handy security feature in it where when the tank is full it shows empty and when empty it shows full. If it gets nicked they will run out of juice.
DC
PostPosted: Tue Oct 12, 2010 5:42 pm
Mods rock!
Just a clock is fine.
PostPosted: Tue Oct 12, 2010 5:47 pm
Mine has the standard speedo, temp, oil, fuel. I have added a nice smiths tacho and I would like to add a smiths clock, but think one small gauge on its own will look silly, so I might also put in volts or .....???
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Oct 12, 2010 6:12 pm
How about a speedo that's accurate?
PostPosted: Tue Oct 12, 2010 6:26 pm
An amp-meter is a pretty handy one. Lets you know what your charging system is doing.
PostPosted: Tue Oct 12, 2010 6:45 pm
Go Rural and chuck in an hour meter, at least youll know how long between something breaking :lol:
PostPosted: Tue Oct 12, 2010 7:18 pm
i disagree. it will only show the current draw at a particular point. and depending on how it is connected its probably not going to mean anything. and thats if you install it correctly and dont burn out wires or set your car on fire. they are more trouble than they are worth.
an oil pressure, a water temp (maybe a battery meter) are all you need
PostPosted: Tue Oct 12, 2010 7:20 pm
Mods rock!
Be sure that it counts down to the minute :wink:
PostPosted: Tue Oct 12, 2010 7:24 pm
Volt, Tacho & Oil Pressure are a must but im also going to have a clock also
PostPosted: Tue Oct 12, 2010 9:03 pm
Mr Orange wrote:
I have a vacuum gauge! It broke and I didn't notice. Don't get one.
I found a period Smiths Vacuum gauge and have it installed in the deluxe. I think it is cool. Got it for about $5.
1966 Morris Mini Deluxe
.... 4 bicycles and 3 screaming kids.
PostPosted: Tue Oct 12, 2010 9:09 pm
I would have to say a constant send temp. gauge, as these are a great back up for the electric.
Volt gauge, clock and Tacho.
don't want to over do it. :wink:
