IwannaMini wrote:
Hmm... re the straps i am trying to move away from traditional/old school ways. I am not too fussed by the paint work or the rattle. Not too fussed by the look of it either.
GT i could fix mine, but do you ever have that "I wonder what else I could do instead" feeling about thigns??? Plus...... after gouging out my head on the bonnet clip thing (far right hand side) the idea of removing the bonnet in total seems ohhhh so nice to me...
Well, fair enough.
Coming back to your list;-
1. Can you mount the bonnet and then not need the hinge (ie lift off / put on and lock in proposition)
2. Is it legal in NSW?
3. Are pins secure enough for a metal bonnet?
4. How do you line the holes up
5. Where can i actually get some?
1. Yes. Locking can be done with some very small padlocks (if you where refering to security)
2. May not be. Could be deemed a sharp forward facing protrusion.
3. Yes.
4. I'd suggest mounting the pins first on the locking panel, make sure they are straight, then winding them down (they are adjustable) until they just touch the inside of the bonnet. Put some msking tape on the inside of the bonnet at around this point. Put a dab of paint on the tips of the pins and close the bonnet once. Then your should have accurately marked the point to drill through.
5. Most speed shops have them. There is a place in West Ryde (Performance World), they would be very likely to have them in stock. You'll need to make a rough measurement of the length as they are available in different lengths (I think from the very distant memory they need to be 4 1/2").
