oil pressure https://www.ausmini.com/forums/viewtopic.php?f=2&t=66333 |
Author: | blake12345 [ Fri Oct 15, 2010 7:48 pm ] |
Post subject: | oil pressure |
Hey i had a quick look but couldnt see anything. Ive just installed a oil pressure gauge and im wondering what a decent oil pressure would be in my 1100cc? Thanks Blake |
Author: | GT mowog [ Fri Oct 15, 2010 7:57 pm ] |
Cold it could reach 100 psi, but anything over 60 would be quite good. Hot over 25 psi but closer to 40 would be happier. |
Author: | blake12345 [ Fri Oct 15, 2010 8:05 pm ] |
ok cool thanks do it reading about 70 when i first turned the car on is ok? Also whats the lowest the oil pressure can get before it starts to be dangerous? |
Author: | drmini in aust [ Fri Oct 15, 2010 8:08 pm ] |
A fresh motor should have 60psi hot @ 2500rpm and up, unless it's a Cooper or S- they run about 70psi when new. Once an engine gets down to 40psi max when hot it needs new bearings and/or a new pump, in my experience. Hot idle, down to 15psi is OK, it's not too bad yet. |
Author: | GT mowog [ Fri Oct 15, 2010 8:11 pm ] |
70 sounds good. The relief valve should be set somewhere around there anyway. Hot at idle, I would want to see no less than 15 but would be happier with 20. On drive, hot, no less than 30. |
Author: | blake12345 [ Fri Oct 15, 2010 8:13 pm ] |
Ok cool thanks. Its a fresh engine thats done about 1200k's. |
Author: | gafmo [ Fri Oct 15, 2010 8:13 pm ] |
70 is perfect when she starts to get low pressure (below 25ish) top the oil up or change the oil & filter. if it doesn't rise its more investigation |
