Brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=66339 |
Author: | gbsmini [ Sat Oct 16, 2010 7:47 am ] |
Post subject: | Brakes |
On a Mini K, what does the T union close to the Brake M/Cyl bolt too I seem to be missing a bracket. |
Author: | GT mowog [ Sat Oct 16, 2010 8:03 am ] |
The Brass 'T' is the 'splitter' between the front and rear brakes. It is very important to re-fit the bracket holding the 'T' piece so the steel lines don't crack (then no brakes). |
Author: | gbsmini [ Sun Oct 17, 2010 1:13 pm ] |
So is there a bracket that it bolts on to. Is there another bracket that comes off the fixed bracket that the clutch hose goes through. |
Author: | gafmo [ Sun Oct 17, 2010 1:41 pm ] |
he T Piece bolts to a Bracket which is then held in place by the Clutch pipe. ![]() |
Author: | gbsmini [ Tue Oct 19, 2010 10:20 am ] |
Thanks. Seem to be missing that bracket. Have made one & all is good.Next question If the adjuster in the front backing plate is a little bit loose can you do anything with them or do you have to get another backing plate |
