Not Starting NOW Starting
https://www.ausmini.com/forums/viewtopic.php?f=2&t=66348
Author:  76van [ Sat Oct 16, 2010 11:44 am ]
Post subject:  Not Starting NOW Starting
Have changed carby from a weber to 1.5" SU & can`t get the bugger to start.
motor winds over fine but just wont start. had this problem with the weber on it had the mechanic sort it & the timing was miles out, could this be the problem with having changed the carby ?
jayson
Author:  GT mowog [ Sat Oct 16, 2010 12:06 pm ]
If it was running OK with the Weber, the timing should definitely be well and truely in the ball park for the SU.
Checked the needle & seat in the float bowl isn't jamed closed?
Jet not blocked?
Choke working?
Take the Bell off the carb and have a look down the jet, you should be able to see the fuel level.
Is the needle close for your applcation?
Author:  simon k [ Sat Oct 16, 2010 12:07 pm ]
no, if the timing was right before, it'll still be right now
basic checks first...
is the float bowl full of fuel? (if no, then the needle and seat is stuck, un-stick it)
do the spark plugs smell of fuel? (if no, then unscrew the big nut under the carb 1/2 a turn and see what it does)
and then you'll have a million more suggestions of what it'll be :lol:
Author:  simon k [ Sat Oct 16, 2010 12:08 pm ]
beat me GT :lol:
Author:  76van [ Sat Oct 16, 2010 5:57 pm ]
thanks,will have a look at this tomorrow hopefully it will have stop snowing by then.
Author:  76van [ Wed Oct 20, 2010 3:49 pm ]
car is now starting & running.
needle seemed to be moving freely,adjusted the mixture nut half a turn down & started fairly easy.
thanks for the advice.
what needle would you run in a mild 1275 ? currently has a 5.
jayson
Author:  jester99 [ Wed Oct 20, 2010 7:57 pm ]
Hi Jayson, good to hear you got it started.
My vizard bible says a good starting needle to try on a 1275 non-S engine with a normal mixture is a DZ with a red spring in the dash pot.
if you want a richer mixture from there, vizard recommends a BQ needle and red spring for a 1275 non-S engine.
If you have access to a rolling road or dyno tuner, i recommend having it setup correctly that way.
otherwise, buy a few different needles and experiment yourself until you feel it is right for you. try the 5 and 6 and see how they go.
i recommend getting a copy of david vizards " tuning the A series engine" 3rd edition. a very good read.
good luck :lol:
