It is currently Mon Jul 21, 2025 4:48 pm
PostPosted: Sun Oct 17, 2010 11:08 am
I have a Fusion stereo in the garage (was planning to fit it to the boat but never got round to it).
It has a remote head + 2 x 6" speakers + 2 x 7" speakers + power unit.
What solutions have people come up with for fitting speakers on a moke?
Ideally I'd fit two in front (somewhere :?: ) and two in the back (somewhere :?: ). I'm not too keen on cutting holes in the panels so I'll probably have to build mounting boxes (was thinking about using marine plastic board).
Any photos to give me some ideas?
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Sun Oct 17, 2010 11:11 am
I would've thought you could mount them anywhere you wanted :)
PostPosted: Sun Oct 17, 2010 11:28 am
I don't think you mount them in the moke, more like on the moke somewhere.
Just put them all in a removable box behind the driver. That's the easiest thing.
PostPosted: Sun Oct 17, 2010 11:47 am
My first moke had speakers in small boxes in the shape of cubes cut diagonally in 1/2. These were mounted beneath the dash so the speakers faced down at 45 degrees. Very unobtrusive but the speakers were smaller than you are talking about.
M
PostPosted: Sun Oct 17, 2010 11:49 am
What make you think that you will be able to hear anything over the wind noise? :lol:
PostPosted: Sun Oct 17, 2010 12:02 pm
They're only for entertaining those around you at traffic lights!
NAV-MAN
Moke + Speakers = does not compute
PostPosted: Sun Oct 17, 2010 12:10 pm
I've got 4" three-ways in my custom dash and they are quite okay at 100km/h with the top down.
Probably the easiest is to make some sort of a box for each speaker. There are lots of ideas on the Moke forum.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sun Oct 17, 2010 4:25 pm
Install near all the other useful items for Mokes - the ashtray and heater.
Lucy - 64 cooper s replica
Lulu - 66 deluxe
PostPosted: Sun Oct 17, 2010 4:33 pm
Don't forget the Japanese mokes had air conditioning, another useful function.
(I guess mainly because when you turn the AC off it's like a turbo button!)
:lol:
 Post subject: Speakers in Moke.
PostPosted: Mon Oct 18, 2010 5:33 am
Try a decent pair of headphones ! You will not need to drill any holes for them. I hope !
"Let us remove your "SHORTS"
PostPosted: Mon Oct 18, 2010 6:34 am
Is that what all those fusion stickers on cars are for?
I never knew.
Can someone then explain pornstar to me?
(Just the stickers, no undesirable links please) :wink:
KB
PostPosted: Mon Oct 18, 2010 7:04 am
A bit more work than your possibly considering but some of the Mazda MX5 seats have speakers in the headrest - perfect for a moke!
PostPosted: Mon Oct 18, 2010 10:13 am
I cant remember who's moke it is, but they have used those pod things that you see in boats (like big eggs) to mount speakers in their moke. Top class if you ask me. They mount on the roll cage.
I have seen other installs including speakers in a box behind the back seat, the back seat removed with the WHOLE back filled with speakers (kind of like how they fill the ute section of a ute with speakers), two speakers in the parcel shelf bit of the dash, a half octagon shaped speaker box behind the gear stick under the dash with a couple of speakers mounted there and then one of the other ideas i like a little bit but not sure how effective they are and not sure if you wanted to cut into the body of your moke, but i have seen a moke that has those directional pods for speakers on the flat top part of the sides with speakers aimed at the driver.
I know you have your own speakers, btu i have also seen a moke with the MX5 seats which have the speakers built into the head rest which i thought was pretty clever too.
PostPosted: Mon Oct 18, 2010 10:25 am
Cutting into the body for speakers in the side pods is not a good idea. The box section which provides much of the strength is severely weakened by doing this.
MX5 seats do look good and work well in a Moke. But I found they sat a little too high for my liking.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
