It is currently Sat Jul 26, 2025 6:54 am
 Post subject: Loose Cones
PostPosted: Mon Oct 18, 2010 6:50 pm
When i jack my car up in the rear the donut, trumpet and rod are loose, ie i can wiggle them and have to be careful that the donut seats in again as the jack goes down.
is this normal / strange / unsafe ?
is there a good visual guide for adjusting hi-lo's anywhere? as i want to re-adjust the front height and make sure the rear is safe.
PostPosted: Mon Oct 18, 2010 7:40 pm
Yes it is normal that they hang loose.
There's a guide on TMF uk for installation of hi-los, with estimates on adjustment:ride height ratios.
http://www.theminiforum.co.uk/forums/in ... opic=10239
tim
 Post subject: Re: Loose Cones
PostPosted: Mon Oct 18, 2010 8:13 pm
Mods rock!
As long as the donuts are not pancakes, if you have your ride hight set that low, you should be running rear shocks for a lowered car to stop this happening. Yes, it can be dangerous.
PostPosted: Tue Oct 19, 2010 6:52 pm
hmmm, my car is not at all low in the rear.... i'll have to take some pics for reference i guess.
