It is currently Mon Jul 21, 2025 6:30 pm
PostPosted: Sat Oct 16, 2010 11:44 am
Have changed carby from a weber to 1.5" SU & can`t get the bugger to start.
motor winds over fine but just wont start. had this problem with the weber on it had the mechanic sort it & the timing was miles out, could this be the problem with having changed the carby ?
jayson
PostPosted: Sat Oct 16, 2010 12:06 pm
Mods rock!
If it was running OK with the Weber, the timing should definitely be well and truely in the ball park for the SU.
Checked the needle & seat in the float bowl isn't jamed closed?
Jet not blocked?
Choke working?
Take the Bell off the carb and have a look down the jet, you should be able to see the fuel level.
Is the needle close for your applcation?
PostPosted: Sat Oct 16, 2010 12:07 pm
no, if the timing was right before, it'll still be right now
basic checks first...
is the float bowl full of fuel? (if no, then the needle and seat is stuck, un-stick it)
do the spark plugs smell of fuel? (if no, then unscrew the big nut under the carb 1/2 a turn and see what it does)
and then you'll have a million more suggestions of what it'll be :lol:
PostPosted: Sat Oct 16, 2010 12:08 pm
beat me GT :lol:
PostPosted: Sat Oct 16, 2010 5:57 pm
thanks,will have a look at this tomorrow hopefully it will have stop snowing by then.
PostPosted: Wed Oct 20, 2010 3:49 pm
car is now starting & running.
needle seemed to be moving freely,adjusted the mixture nut half a turn down & started fairly easy.
thanks for the advice.
what needle would you run in a mild 1275 ? currently has a 5.
jayson
PostPosted: Wed Oct 20, 2010 7:57 pm
Hi Jayson, good to hear you got it started.
My vizard bible says a good starting needle to try on a 1275 non-S engine with a normal mixture is a DZ with a red spring in the dash pot.
if you want a richer mixture from there, vizard recommends a BQ needle and red spring for a 1275 non-S engine.
If you have access to a rolling road or dyno tuner, i recommend having it setup correctly that way.
otherwise, buy a few different needles and experiment yourself until you feel it is right for you. try the 5 and 6 and see how they go.
i recommend getting a copy of david vizards " tuning the A series engine" 3rd edition. a very good read.
good luck :lol:
Users browsing this forum: Bing [Bot], timmy201 and 75 guests
