It went bang...[with pics] https://www.ausmini.com/forums/viewtopic.php?f=2&t=66569 |
Page 1 of 2 |
Author: | My_Mini_Rocks [ Wed Oct 27, 2010 10:40 am ] |
Post subject: | It went bang...[with pics] |
Thought you may all like a look at a job that came in the other day. It would be really great if we had a topic started that i (or others) could throw pictures in. Anyhow here is an 1100cc crank and gearbox: ![]() ![]() |
Author: | MINTI [ Wed Oct 27, 2010 1:01 pm ] |
Author: | mini maxx [ Wed Oct 27, 2010 1:22 pm ] |
ooohh SNAP!! |
Author: | jester99 [ Wed Oct 27, 2010 1:29 pm ] |
BIG BOOMBA! was that a standard crank or a race engine or what? |
Author: | Wombat [ Wed Oct 27, 2010 1:31 pm ] |
MINTI wrote: :shock: how does that even happen?!
Maybe leaving the overthrow nut off the clutch ![]() |
Author: | david rosenthal [ Wed Oct 27, 2010 1:54 pm ] |
metal stress , out of balance forces, any number of things. very unusual for the web to crack there, I would suspect that the crank has distorted or the block /mains are misaglined and the stress point is then acting on the web. |
Author: | Molina [ Wed Oct 27, 2010 2:28 pm ] |
This is what happened to a friend's car on the weekend at Winton. ![]() We're pulling the motor apart on Saturday to find out what happened. The theory at the moment is a dropped valve. Motor is a turbo 20valve 4AGE. |
Author: | jester99 [ Wed Oct 27, 2010 2:34 pm ] |
EWWWW that doesnt look good! |
Author: | subwayseth [ Wed Oct 27, 2010 2:44 pm ] |
Molina wrote: Motor is a turbo 20valve 4AGE.
i love the 4age ![]() |
Author: | awdmoke [ Wed Oct 27, 2010 2:57 pm ] |
Molina wrote: ![]() Motor is a turbo 20valve 4AGE. Correction. The motor was a turbo 20valve 4AGE. |
Author: | mini maxx [ Wed Oct 27, 2010 3:06 pm ] |
Now its a 19 valve 4AGE ![]() |
Author: | GT mowog [ Wed Oct 27, 2010 3:51 pm ] |
Perhaps not as spectacular as some above, but ![]() 1100 engine which had a big end let go. Wreaked (shortlist);- Crank Block Rod Piston Camshaft Gearboxcase About the only items that were salvagable was the head and rocker gear. |
Author: | Rodney [ Wed Oct 27, 2010 3:55 pm ] |
Some very tasty samples there ![]() |
Author: | mini_mad_matt [ Wed Oct 27, 2010 6:06 pm ] |
Slightly off the topic Customer towed in a late model BMW a week ago because they drove it into flood water. So we took the plugs out and started trying to turn it over, but it wouldn't budge, so we jacked it up and oil started running out ![]() There is a hole big enough for my hand to fit through in the side of the block. So remember peoples, if your not sure wether its low enough to drive through, don't try it! Especially if you own a nice expensive BMW. |
Author: | Molina [ Wed Oct 27, 2010 9:03 pm ] |
awdmoke wrote: Molina wrote: ![]() Motor is a turbo 20valve 4AGE. Correction. The motor was a turbo 20valve 4AGE. It had been running 19psi for about a month or two. The little 1.6 made 240 rear wheel kW. The boost got turned down to 10psi for the weekend at the track and that's when it went bang. Moral of the story? |
