Head Coolant Bypass Thread Size
https://www.ausmini.com/forums/viewtopic.php?f=2&t=66616
Author:  woodwormm [ Sat Oct 30, 2010 12:57 pm ]
Post subject:  Head Coolant Bypass Thread Size
does anyone know what size thread this pesky little thing is?
it appears the nipple that goes into the head for the coolant bypass is so corroded on mine, i cannot get enough purchase on it with a hose clamp...
i don't like my fancy new red coolant on the floor
i know it's a contentious issue whether to plug this or not. i'm thinking i'll plug it.
so what size thread is it?
should i use brass or steel plug? does it matter?
cheers.
Author:  GT mowog [ Sat Oct 30, 2010 3:27 pm ]
Post subject:  Re: Head Coolant Bypass Thread Size
cheers.
5/8" UNF. I use steel plugs but I also use a good coolant / inhibitor.
Author:  drmini in aust [ Sat Oct 30, 2010 5:52 pm ]
I make DrMini ST brass adaptors. Never rust out like the originals do. 8)
However if plugging it off, a steel plug will work fine.
Author:  woodwormm [ Sat Oct 30, 2010 6:35 pm ]
hmmm, i've been wanting some DrMini porn parts on my car for a while now.... :lol:
Doc, how long is the "barb" for want of a better term, or smooth nipple, on your adaptors?
i'm trying to use a wide clamp on a kevlar hose but my old adaptor does not have enough left in it for the clamp to grab on to....
Doc are yours barbed or have a 'bead' on the end?
Author:  drmini in aust [ Sat Oct 30, 2010 6:44 pm ]
Mine are straight, no barbs, I turn them from a BOC gases oxy hose joining nipple. I've never had a leak problem with std rubber 1/2" radiator hose on there.
Length of the straight bit (guess) is around 1/2".
Author:  woodwormm [ Sat Oct 30, 2010 6:46 pm ]
hmm i like the idea of using radiator/heater hose, why'd i not think of that before...
pm sent.
