It is currently Thu Jul 24, 2025 6:20 am
 Post subject: single or twin rc40?
PostPosted: Wed Oct 27, 2010 11:38 pm
Milatsmadmini
shopping.... gotta love having KC just around the corner... single or twin box rc40? is a single going to be too loud?
PostPosted: Thu Oct 28, 2010 12:14 am
Wow, i was working on derby street for about a month, and never even went into karkraft..
I was a stones throw away!
I would get twin RC40's, one on either side.
I'm a sucker for twin exhausts
You're so square
Baby I don't care
PostPosted: Thu Oct 28, 2010 5:53 am
I have a 1275 with head work and a cam and it can get pretty loud with a single muffer............if your driving a long way that drone can get pretty dam irritating!!
Hi-Ho Silver LS1275
PostPosted: Thu Oct 28, 2010 6:32 am
Matt,
The older you get (or I get plus several ausmini mates I know) the quieter you want your car to be. I'm pretty sure Doc, GR and Lillee etc have done some engine dyno tests and the benefit you get from running a single RC40 doesn't outweigh the quiet sweet note of a twin box setup.
PS Adam, this isn't a twin exhaust setup; it is two mufflers in series along the same pipe.
When I had mine, I was going to go down the twin box and 1.75 SU route replacing a lukey single and 45DCOE to quieten it down!
But on the flip side - you're only young once and you're going to go deaf at some stage anyhow :lol:
PostPosted: Thu Oct 28, 2010 6:51 am
Mods rock!
I find the single box RC40 quite OK and acceptable with Cams up to about 265 - 270 deg timing, more than that and a twin box set up to get rid of the resonant bark at certain RPMs. This will depend on your particular engine displacement and head specs too.
PostPosted: Thu Oct 28, 2010 8:47 am
How loud is loud? - half watching one of those 'reality' cop shows last night a young bloke in NSW was pulled over for loud exhaust. At the end of the segment it said on the screen that the limit was" 90dB about the same as a hairdryer" - it would depend how close but does that sound right (forgive the pun)
David L
PostPosted: Thu Oct 28, 2010 8:52 am
I've had a single and a twin box set up on Slidey. Without a doubt I would recommend the single. It's not too loud at all.
PostPosted: Thu Oct 28, 2010 9:34 am
I have a twin setup as I found the single RC40 a bit too loud.
I have also found the noise is louder as the exhaust ages.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Oct 28, 2010 1:31 pm
I ran a single box RC40 on the 1360 with a 282 cam, yes it had a bit of a bark. But not excessive.
I now have a 2" system, and the bark is a bit louder. :P
PostPosted: Thu Oct 28, 2010 7:50 pm
The twin RC40 will give you a little more power over the single box and you get to keep your hearing as well :D . That said, I have the lukey straight through muffler with glass stuffing...loud and you get that lovely "bratt bratt bratt" at idle.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Thu Oct 28, 2010 7:51 pm
Supercharged
single for loud, twin for performance.
PostPosted: Thu Oct 28, 2010 7:56 pm
In loss I am talking a poofteenth less using the single box vice the twin. I like the lukeys as they are easy to fit and have a turned up exit. I had the twin but it kept breaking the rear mounts. The lukeys never broke :D
This said though - I have to get my arse into gear and get mine back on the road!!
Rob Forsyth
Miniot!!
PostPosted: Thu Oct 28, 2010 8:17 pm
Supercharged
hey a poofteenth more hp on a mini is worth it :)
a long time ago i had a single straighthrough lukey with centre exit on a smallblock, god did that sound awesome.
PostPosted: Thu Oct 28, 2010 10:49 pm
Milatsmadmini
single it is!
hell if i get bored of it, ill just add a hot dog to it... (doubt it :twisted: )
Gotta love KC... cheap cheap cheap
single box, connecting pipe and fitting kit, for $130.... nice!
now the next part... do i weld the bottom of the manifold to the connecting middle pipe or clamp the beh-jesus out of it?
PostPosted: Thu Oct 28, 2010 10:53 pm
how does having having two restrictions equate to having more power than one?
