It is currently Sat Jul 19, 2025 11:52 am
PostPosted: Sat Dec 18, 2010 6:00 pm
I've got to pick up a pair of needles for my twin 1.25 SUs on stock MOWOG twin manifold. Can I please have some opinions on starter needles to set my new engine up with.
I've got a 998 at 100 thou over for a displacement of 1075. The camshaft is GR's RE83. The head is a 295 set at about 9.5:1 and 3:1 extractors.
Can anyone give me a few selections to try out?
PostPosted: Sat Dec 18, 2010 6:06 pm
CP4 or MME would be the preferred needles to start with
PostPosted: Sat Dec 18, 2010 6:31 pm
i`d stick a pair of "M"`s in them first & see how they run
CP4`s & MME`s are more suited to a mild/hot-ish 1275 on twin 1.5 carbs
PostPosted: Sat Dec 18, 2010 7:03 pm
Engine Size Needle Std Needle Rich Needle Lean Spring Type
850 comp
1071 S Comp MME - - Blue
997 Cooper
thermo jets MME - - Blue
998 Cooper
modified head AO - - Blue
970 Cooper S
comp CP4 - - Blue
Thats from a BMC Tuning page I found ages ago , they have same details on Seven Enterprises
( it looks strange as I cant make it line up properly :? )
PostPosted: Sat Dec 18, 2010 7:09 pm
M's I would not have picked as a choice, I have always thought the selections were based on capacity first..shows I have a lot to learn still....I have a pair here as it is however, so it won't hurt.
PostPosted: Sat Dec 18, 2010 7:53 pm
Ms seem to work well in tuned 1098s so should in yours too.
AH2 is a bit richer than M, if you need this.
PostPosted: Sat Dec 18, 2010 10:13 pm
I even happen to have a pair of those too.. :D
I'm set it seems!
PostPosted: Sat Dec 18, 2010 11:09 pm
I'm using M needles in my cooper I bought new ones 3 & 4 cylinder and not firing plugs very wet the needle measured up at 75 thou at the idle end instead of 87 thou like the other one on cylinder 1&2
PostPosted: Sun Dec 19, 2010 8:31 am
Mods rock!
Mick wrote:
......... I have always thought the selections were based on capacity first...
Actually Torque / HP. Find an engine with a similar torque / HP curve to what you expect yours will have. That will be a very good starting point.
And don't overlook the springs.
PostPosted: Sun Dec 19, 2010 9:14 am
yeah pretty right
I will add tho, that it`s more about "air speed" through the carb
a really big carb on a small , low reving, engine will need a much richer needle profile than a smaller carb on the same engine... the smaller carb will pull up the fuel from the jet far better with the higher air speed
& with a small carb on a very big high reving engine will only need a fairly lean needle profile,,, etc etc etc,,, that`s the part where GT mentions how the spring rate affects things
i recently sent a single 1&3/4 carb to a guy (way out west somewhere) to fit onto a massive 4.5litre straight 8 (of some sort) & i set it up with the same old OA6 needle & Red spring ,,, the very same "base-setting" that i do with every thing to start with
he rang me back telling me how he couldn`t believe how good it was & no need for any tune work,,, (his actual words were "It`s spot on" )
Now i`m sure we could have improved it a tad more with some time playing, but he was more than satisfied
however, if it were a race engine (higher revs & obviously much higher air speed through the carb) well i guarantee it would have needed much more than a play with to get it right (maybe add a few more carbs to be honest) but still,,, as big as the engine is , it still had fairly low revs, so air speed wasn`t too fast to cause any issue & my faithful old "std" base setting was sweet
so,,, there you go,,, think "air speed" more than anything & you`ll be on the right track
PostPosted: Sun Dec 19, 2010 9:28 am
I'm set it seems!
Mick the "M" needles should be all you will need for this size engine (Im not 100% sure of specs of your cam but I dare say its "nice" :wink: ) but as the good Doc said if you need slightly richer AH2's will do the job.
