pod filter ramflo https://www.ausmini.com/forums/viewtopic.php?f=2&t=66712 |
Page 1 of 2 |
Author: | toolie [ Wed Nov 03, 2010 8:09 am ] |
Post subject: | pod filter ramflo |
Just fitted a ramflo filter to my 998 clubbie.Started it up , its now barely running, engine is idling very rough, sparkplugs are carboned up really badly. Any ideas anyone? |
Author: | simon k [ Wed Nov 03, 2010 8:32 am ] |
Post subject: | Re: pod filter ramflo |
toolie wrote: Any ideas anyone?
yep - take it off again! it's running rich, meaning not enough air is getting through, meaning the filter is restricting airflow, meaning it's worse than what was there before |
Author: | GT mowog [ Wed Nov 03, 2010 9:07 am ] |
Provided it has been correctly fitted, did you over oil it? |
Author: | toolie [ Wed Nov 03, 2010 1:02 pm ] |
I haven't oiled it at all |
Author: | GT mowog [ Wed Nov 03, 2010 2:00 pm ] |
You haven't fitted the backing plate up-side-down? The is of course the big hole through the centre, and the two samller mounting holes. There should also be another two holes between these two off set towards the top. These allow air to move as required from under the piston in the carb. If the backing plate is on up-side-down, this vent is blocked and the car will hardly run. Here's a pic ![]() If you refer to the 'Not To Scale' sketch, it shows the correct way to fit it. |
Author: | mini maxx [ Wed Nov 03, 2010 7:12 pm ] |
Theyre crap, chuck it away |
Author: | tuff998 [ Wed Nov 03, 2010 8:34 pm ] |
Ive got a ramflo filter on my 998. works a treat ![]() |
Author: | Tombo [ Wed Nov 03, 2010 9:36 pm ] |
tuff998 wrote: Ive got a ramflo filter on my 998. works a treat
![]() +1 on my 1100. After the day at Hay in the dust, it runs fine, the outside is dirt and the inside is oily foam... Works for me ![]() |
Author: | mini maxx [ Wed Nov 03, 2010 9:48 pm ] |
Geez, i bunged one on my 1275 and it ran worse than a 3 legged dog, went back to stock after much fiddling and it runs well |
Author: | VulcanBB18 [ Wed Nov 03, 2010 9:50 pm ] |
I've always hated the damn things but people seem to get decent results out of them, so they gotta work in some respects! cheers' Jacob |
Author: | Tombo [ Wed Nov 03, 2010 9:51 pm ] |
Mine does have a custom AWESOME ram intake in there too ![]() |
Author: | Kennomini [ Wed Nov 03, 2010 10:14 pm ] |
Go K&N, better filtering and good flow. |
Author: | haze blue 850 [ Wed Nov 03, 2010 10:34 pm ] |
Greeting All. GT MOWOG. I put a couple pan-cakes on my project today. Glad I read this as I didn't even consider what those holes were for. I'm gonna check their on right in the morning. Hope to start it before the weekend. Alex. |
Author: | GT mowog [ Thu Nov 04, 2010 3:43 am ] |
Kennomini wrote: Go K&N, better filtering and good flow. +1 on that - big time. I don't like the Ramflo as they 'leak'. I know the Doc swears by them, but I think he runs an after market element. haze blue 850 wrote: Greeting All.
GT MOWOG. I put a couple pan-cakes on my project today. Glad I read this as I didn't even consider what those holes were for. I'm gonna check their on right in the morning. Hope to start it before the weekend. Alex. Ah, yes....attention to detail, attention to detail........ ![]() |
Author: | '77 clubby van [ Thu Nov 04, 2010 8:39 am ] |
I have one on my 102kW @ the wheels Toyota starlet GT 4efte conversion. I upgraded to the (unifilter?) aftermarket element though. Seems a lot better quality, but that said I never ran it with the standard element because of what people here said about them. RE: the rough running, As said, make sure all hoses on the carby are in place and the ones that were connected to the air filter still are. ![]() |
