It is currently Sat Aug 16, 2025 12:26 am
 Post subject: 998 height vs 1275
PostPosted: Sun Nov 21, 2010 9:57 pm
as per title; how much taller is the 1275 than a 998/1100?
I am in the process of making a weber box for my Moke, and need to start dimensioning up some things.
PostPosted: Sun Nov 21, 2010 10:01 pm
only about 1/4 inch,,, shouldn`t be an issue with the weber box as most weber manifolds lift up away from the head quite a fair bit
PostPosted: Sun Nov 21, 2010 10:04 pm
Excellent.
6mm should be neither here nor there.
I am running a GR 5" (or is it 7, I forget.... - anyway his normal road one) manifold, so will need to relieve the firewall to suit.
Going to be running 'socks' over ramtubes.
PostPosted: Mon Nov 22, 2010 4:31 am
Mods rock!
I've actually measured it at 3/8" on a few un-machined blocks.
PostPosted: Mon Nov 22, 2010 6:27 pm
Me too. :wink:
