It is currently Fri Jul 18, 2025 3:28 pm
PostPosted: Thu Nov 11, 2010 5:33 pm
Supercrap have got their 10inch or 12 inch fans out on special
you buy 2 for $79.
usually $69 each.
i bought 2 10 inchers (insert all your lude thoughts here)
i reckon my metal fan will disappear one day soon
thought i'd share as there's been a lot of talk on here about electric fans.
PostPosted: Thu Nov 11, 2010 5:35 pm
Milatsmadmini
do a duel fan set up, one push, the other pull... or duel radiators.... oh the possibilities are endless!
PostPosted: Thu Nov 11, 2010 5:38 pm
i was wondering if the radiator sandwich in two fans was a little overkill?
mattsmadmini you're validating my crazy ideas
PostPosted: Thu Nov 11, 2010 5:46 pm
If your cooling system needs two fans you are only treating the symptoms not eliminating the true cause
David L
PostPosted: Thu Nov 11, 2010 6:40 pm
nah mine doesnt,
i was just being silly. can't resist a bargain so i got two fans...
one'll end up on the next project or possibly an extraction system for the workshop... got a 10amp 240 to 12 volt transformer floating around somewhere...
