It is currently Wed Jul 23, 2025 9:15 am
PostPosted: Sun Nov 07, 2010 5:31 am
The dan pin that holds the rod change in
Has popped out! Stuck in 4th gear lol
Does this happen often? Is there a easy fix.
I have got the car towed to my gf's in clevland qld.
If there is any one who can help me fix it Monday or sunday arvo ?
would be great!
What about put a nut and bolt through it? To get me home?
PostPosted: Sun Nov 07, 2010 6:28 am
just to get it home, put in a nail or something thats a close fit and bend the ends down.
at home fit a new pin, should be a tight fit and never come loose on its own, but you may run a lenght of wire through it and drill the ends together
Rover 214 atm ....
PostPosted: Sun Nov 07, 2010 10:44 am
YEP this is dead right... do exactly this. The wire just ensures that it wont fall out ever again... about a 5 minute job really...
im suprised you couldn't tell it was on its way out, your gear stick would have had massive amounts of movement than it should getting worse over the last few months...
PostPosted: Sun Nov 07, 2010 11:21 am
Some of our gear sticks have massive amounts of movement anyway. Perhaps that's something I'll check on mine. I've never driven a mini except for mine - I'm not sure what it should feel like :roll:
PostPosted: Sun Nov 07, 2010 11:42 am
yep, theres always massive amounts, however there is a certain amount acceptable I would have to say.. :lol:
My 1380 rod change I rebuilt, all the linkages etc, and changed the roll pin, and its tight as hell now :D
PostPosted: Sun Nov 07, 2010 7:50 pm
nothing wrong with a tight box :wink:
PostPosted: Sun Nov 07, 2010 7:57 pm
i second that,or a nice beaver...
First you get the money,then you get the power,then you get the Mini.
PostPosted: Mon Nov 08, 2010 9:11 am
It's odd it is all new. New pins was tight as he'll.
No play, it's just poped out.
The back pin poped out not the front one
That links to the engine.
PostPosted: Mon Nov 08, 2010 2:41 pm
well very dodge but a nail with some tape bent over got me home.
thanks Klas :lol:
PostPosted: Wed Nov 10, 2010 8:51 pm
I know ur pretty busy atm Lockie but is there any chance you could post a picture?? Ive got heaps of play in my gearstick so its probably something that I should look into aswell.
Pleasee :(
Lil yellow clubbie
PostPosted: Wed Nov 10, 2010 8:56 pm
i put a new pic back in it's back tight again.
you should check if the pin is making it's way out.
it's super easy to do mate.
Users browsing this forum: Pottsy and 77 guests
