Yosuke i think he name is on holidays in japan
so you will deal with his japanese wife bad SLOW english lol.
she is lovely but it is painfull ordering.
BE CLEAR & SLOW WITH EVERYTHING LOL.
you can run a lower ride height & if you jack the car up they don' fall out.
if you jack the wheel up it self really high like im talking compressing the crap out of it you can move them about.
it's a myth the hole them failing out under normal circumstances it's hard to explain really with out putting them in & understanding how it works.
iI doubt you will have a problem.
put it this way, I had to jack the car up about 4 or 5 times to get the wheels on & off, sometimes both at the same time jacked up high to get the ride hight close & they never dropped out once & stayed under compression the hole time.
ge the fast road kit & get new joints & replace any rubbers while you are at it.
but the lower you run the less compression it has.
i have mine a bit under standard height works fine but i set my shocks to soft so it's a bit of a joke how smooth it is really.
not use to it lol
QUTOE FROM YOSUKE
Regarding the dis-lodging It will not happen if you would set the car not too low with putting shorter rear damper which restrict the fall of trailing arm. If you would go very low like track car you would need to put helper spring or insert a small spring into the center hole of the height adjust nut. It will not happen if you would fit them with CSTR644 and set in the reasonable height- 1inch clearance at the front wheel arch from the tyre top.
