It is currently Sat Jul 19, 2025 8:14 pm
PostPosted: Thu Nov 04, 2010 5:27 pm
Hey all, Just some things I noticed today :shock:
1- The clubby is running lean, now richened :)
2- A internal rattle that disappeared when given a hard rev (oil pressure isssue I imagine)
3- my compression is way out :?
Warm 1-120psi 2-90psi 3-90psi 4-90psi
oiled 1-115psi 2-105psi 3-145psi 4-140psi
WTF with No.1
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Thu Nov 04, 2010 5:30 pm
Adjust the tappets then repeat the compression test :idea:
PostPosted: Thu Nov 04, 2010 5:33 pm
I did them a few weeks ago and are all good
PostPosted: Thu Nov 04, 2010 5:52 pm
Then I've got no idea how compression can go down on #1 after adding oil.
PostPosted: Thu Nov 04, 2010 6:03 pm
hah yea ay WTF, mystery of the mini engine lol
PostPosted: Thu Nov 04, 2010 8:00 pm
just lucky :D
getting close to time for a rebuild - you're going to double your investment in the car!
PostPosted: Thu Nov 04, 2010 8:01 pm
impending rebuild i reckon
PostPosted: Thu Nov 04, 2010 8:11 pm
hmm yea I think so, I wonder if Minisport could so something before minis at the mill
PostPosted: Thu Nov 04, 2010 8:14 pm
Mods rock!
and a new compression tester......
PostPosted: Thu Nov 04, 2010 8:18 pm
pfft, it'll keep going for a couple of years at least...
PostPosted: Thu Nov 04, 2010 8:22 pm
it is a new tester lol. and its also leaking oil from the back anyway. Ill see what happens
PostPosted: Sat Nov 06, 2010 11:55 am
OMG our nightmare came true :'(
I took it down to minisport and the guys had a look. Figured out that my compression should be 175 and I have have of that :shock: That and apparently it was blowing a bit of white smoke out the rear on the way down.
So theyre gonna strip her down and see whether it needs rings or bore.
maybe I can use this opportunity to put flat-tops in and a cam :P
PostPosted: Sat Nov 06, 2010 1:07 pm
Supercharged
rattle probably your timing chain?
a week isnt long enough for a rebuild, but see how ya go.
no such thing as rings only on an a-series as they wear the bores oval, its a rebore or you'll be back again soon enough.
PostPosted: Sat Nov 06, 2010 1:32 pm
nah the timing chain has always been noisey lol. this aother rattle is like when there is no oil pressure in the big end bearings.
anyway they said theres a very good chance they can get it done. and the worse case scenario can be a good one.. a bigger bore :P
PostPosted: Sat Nov 06, 2010 4:12 pm
Supercharged
yer nick is getting his mini done this week there also, fingers crossed.
Users browsing this forum: No registered users and 68 guests
