It is currently Sat Jul 19, 2025 2:31 pm
PostPosted: Fri Nov 12, 2010 2:52 pm
Mine has an air leak in it now, and so I bleed the air out then about 10 minutes later I have no clutch again.
I peeled back the slave cylinder boot and saw fluid in there. So are they a straight forward replacement or is there a special procedure?
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Fri Nov 12, 2010 3:01 pm
ohh, come on - your sig says you're a mechanic!
just bung the new one on
PostPosted: Fri Nov 12, 2010 3:02 pm
Hone and a seal.
PostPosted: Fri Nov 12, 2010 3:04 pm
lol yes i am, but sometimes minis have their own way of things lol.
PostPosted: Fri Nov 12, 2010 3:18 pm
Hone and a seal.
Works better and longer than some of the new ones. :wink:
PostPosted: Fri Nov 12, 2010 3:40 pm
Hone and a seal.
I have seen new cylinders with casting flaws and split rubbers.
The only way to tell if it is any good is to build it yourself.
Even when I buy a new cylinder I will dismantle it, clean it, inspect it and reassemble it. It saves time.
PostPosted: Fri Nov 12, 2010 3:42 pm
Mods rock!
and bleed it!
PostPosted: Fri Nov 12, 2010 4:26 pm
Kinda like a "Tiny" Mechanic perhaps??
PostPosted: Fri Nov 12, 2010 7:32 pm
Milatsmadmini
:lol:
PostPosted: Sat Nov 13, 2010 5:48 pm
ok then. I replaced all the hydraulics including fitting a braided clutch hose :) took me two hours to remove the stubborn and siezed pin that connects to the clutch pedal lol. and after ages of bleeding all is good.
PostPosted: Sat Nov 13, 2010 6:31 pm
I purchased a new one months ago, put it on, bled it and it took on a life and style of its own, it now sits in the shed as the old weepy one worked better
PostPosted: Sat Nov 13, 2010 6:38 pm
Many new ones have a design fault, the plastic spreader inside the seal is the wrong shape. So the seals don't work for long.
If you must use a new slave, pinch the plastic spreader out of the old one.
In 36 years of Mini-ing I have never been guilty of buying a new slave cylinder.
A quick hone of the old one and new seal, they run another 20 years. 8)
PostPosted: Sat Nov 13, 2010 7:18 pm
yea i got a new one and put the updated seal in it. the one that comes with it only has about 2mm sealing area and the updated one has about 4-5mm.
PostPosted: Sat Nov 13, 2010 7:20 pm
So that means you must've started Mini-ing when you were five years old!?
PostPosted: Sat Nov 13, 2010 8:41 pm
Maybe I'm a little older than you think then.:mrgreen:
