Checking idler gear endfloat with the engine still on box https://www.ausmini.com/forums/viewtopic.php?f=2&t=66929 |
Author: | drmini in aust [ Fri Nov 12, 2010 12:17 pm ] |
Post subject: | Checking idler gear endfloat with the engine still on box |
Idler gear endfloat felt a bit much with my fingers, so I made a jigger up to measure it in situ. The bent bit of welding wire pulls the gear outwards, the dial gauge pushes it inwards. After milling .005" off the housing flange, I now have .002" endfloat. Not quite enough, so I'll now swap the .133" thrust washer for a .131". |
Author: | VulcanBB18 [ Fri Nov 12, 2010 7:37 pm ] |
Very cool trick ![]() cheers Jacob |
Author: | kiwiinwgtn [ Fri Nov 12, 2010 8:04 pm ] |
Hi Kev A man of your talents i thought you would make up a bearing idler gear and biff those terrible idler washers for once and for all. The one I had done by an Ausmini member is awersome.. Kiwiinwgtn |
