Clutch slave cylinder replacement
https://www.ausmini.com/forums/viewtopic.php?f=2&t=66931
Page 1 of 2
Author:  tuff998 [ Fri Nov 12, 2010 2:52 pm ]
Post subject:  Clutch slave cylinder replacement
Mine has an air leak in it now, and so I bleed the air out then about 10 minutes later I have no clutch again.
I peeled back the slave cylinder boot and saw fluid in there. So are they a straight forward replacement or is there a special procedure?
Author:  simon k [ Fri Nov 12, 2010 3:01 pm ]
ohh, come on - your sig says you're a mechanic!
just bung the new one on
Author:  Morris 1100 [ Fri Nov 12, 2010 3:02 pm ]
Hone and a seal.
Author:  tuff998 [ Fri Nov 12, 2010 3:04 pm ]
lol yes i am, but sometimes minis have their own way of things lol.
Author:  drmini in aust [ Fri Nov 12, 2010 3:18 pm ]
Hone and a seal.
Works better and longer than some of the new ones. :wink:
Author:  Morris 1100 [ Fri Nov 12, 2010 3:40 pm ]
Hone and a seal.
I have seen new cylinders with casting flaws and split rubbers.
The only way to tell if it is any good is to build it yourself.
Even when I buy a new cylinder I will dismantle it, clean it, inspect it and reassemble it. It saves time.
Author:  GT mowog [ Fri Nov 12, 2010 3:42 pm ]
and bleed it!
Author:  Hanra [ Fri Nov 12, 2010 4:26 pm ]
Kinda like a "Tiny" Mechanic perhaps??
Author:  mattsmadmini [ Fri Nov 12, 2010 7:32 pm ]
:lol:
Author:  tuff998 [ Sat Nov 13, 2010 5:48 pm ]
ok then. I replaced all the hydraulics including fitting a braided clutch hose :) took me two hours to remove the stubborn and siezed pin that connects to the clutch pedal lol. and after ages of bleeding all is good.
Author:  mini maxx [ Sat Nov 13, 2010 6:31 pm ]
I purchased a new one months ago, put it on, bled it and it took on a life and style of its own, it now sits in the shed as the old weepy one worked better
Author:  drmini in aust [ Sat Nov 13, 2010 6:38 pm ]
Many new ones have a design fault, the plastic spreader inside the seal is the wrong shape. So the seals don't work for long.
If you must use a new slave, pinch the plastic spreader out of the old one.
In 36 years of Mini-ing I have never been guilty of buying a new slave cylinder.
A quick hone of the old one and new seal, they run another 20 years. 8)
Author:  tuff998 [ Sat Nov 13, 2010 7:18 pm ]
yea i got a new one and put the updated seal in it. the one that comes with it only has about 2mm sealing area and the updated one has about 4-5mm.
Author:  winabbey [ Sat Nov 13, 2010 7:20 pm ]
So that means you must've started Mini-ing when you were five years old!?
Author:  drmini in aust [ Sat Nov 13, 2010 8:41 pm ]
Maybe I'm a little older than you think then.:mrgreen:
