It is currently Fri Jul 18, 2025 3:59 pm
 Post subject: tank sealing
PostPosted: Sat Nov 13, 2010 7:51 am
I'm looking to use por15 tank seal in my twin tanks is there filters inside the tanks that might need removing first
PostPosted: Sat Nov 13, 2010 7:54 am
Yes. There is a nylon strainer in there. They are mounted directly on the ends of the pick-up pipes, fairly difficult to see (I put an inspection camera in there, that was how I found them). The one on the LH tank you could probably get off through the sender hole. The RH tank, well, have fun!
Users browsing this forum: Bing [Bot] and 92 guests
