It is currently Thu Aug 07, 2025 1:13 am
PostPosted: Tue Nov 16, 2010 7:40 pm
I am fitting new cork seals on the side covers. How tight should the bolt be done up?
PostPosted: Tue Nov 16, 2010 7:56 pm
Mods rock!
If they are the raise type, 2 ft/lbs and the depressed type 5 ft/lbs. See if you can get a hold of the Neoprene ones, they are much better.
PostPosted: Wed Nov 17, 2010 7:01 pm
How can I tell the difference between raised and depressed?
PostPosted: Wed Nov 17, 2010 7:05 pm
Mods rock!
With the raise ones the centre where the bolt goes through, sits higher than the gasket face. The depressed one is the other way.
Any chance of a pic?
