Side cover seals - how tight?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67052
Author:  jme [ Tue Nov 16, 2010 7:40 pm ]
Post subject:  Side cover seals - how tight?
I am fitting new cork seals on the side covers. How tight should the bolt be done up?
Author:  GT mowog [ Tue Nov 16, 2010 7:56 pm ]
If they are the raise type, 2 ft/lbs and the depressed type 5 ft/lbs. See if you can get a hold of the Neoprene ones, they are much better.
Author:  jme [ Wed Nov 17, 2010 7:01 pm ]
How can I tell the difference between raised and depressed?
Author:  GT mowog [ Wed Nov 17, 2010 7:05 pm ]
With the raise ones the centre where the bolt goes through, sits higher than the gasket face. The depressed one is the other way.
Any chance of a pic?
