mmiller6512 wrote:
Thanks All.
It was picked up with a chain through the doors by a backhoe.
I maybe should have left it where it was but that was 15 years ago.
So the gutters are bent but i think repairable ? The roof is ruined.
Generally speaking, on most mini's, if there is no reason to cut thru the a,b and c pillars I won't. If you do, you
WILL need to brace the rest of the the body. The Turrets are usually either spot welded or risistance welded. If it is spot welded, just drill out the spot welds and split the turret off... if its resistance welded grind it off with a cut off wheel (as close to the gutter as possible) and then grind the remains of the old roof out of the gutter.
There is a rail that runs right round the inside of the gutter that the hood bows clip into for the interior, there is sufficient strength in this and the gutter to support the body (provided you don't try and move the body around too much).
