Points Dizzy
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67065
Author:  minimuts01 [ Tue Nov 16, 2010 11:06 pm ]
Post subject:  Points Dizzy
So the distributor has points in it but there is no vaccum advance how can i tell if there is some other mechanical advance built into it or if its just a dodgey distributor? its not picking up power under load like it should.
Thanks in advance.
Author:  Convertible Mini [ Wed Nov 17, 2010 6:08 am ]
Post subject:  Mechanical advance
Easiest test is to take the Cap off and see if the rotor button can be rotated by hand a few degrees with the engine stationary of course and make sure it also springs and returns back to the original position.
Author:  Irish Yobbo [ Wed Nov 17, 2010 7:54 am ]
Post subject:  Re: Points Dizzy
minimuts01 wrote:
Thanks in advance.
He he... :lol:
Author:  minimuts01 [ Wed Nov 17, 2010 9:32 am ]
Post subject:  Re: Mechanical advance
yeah so it rotates a few degree and springs back to the original position.
here's some pics:
Author:  tuff998 [ Wed Nov 17, 2010 9:35 am ]
my dizzy was like that. only had mechanical advance :( but then I bought a new dizzy which had electronic ignition and vac advance. and holy moley it makes a difference having vac advance lol :)
Author:  simon k [ Wed Nov 17, 2010 10:38 am ]
what sort of difference?? vacuum advance is for economy - IE it advances when there is vacuum in the manifold, IE when you're only lightly touching the accelerator. Put your foot down and it goes away
I think your "holy moley" is from the electronic ignition, and the dizzy not being worn out :wink:
Author:  drmini in aust [ Wed Nov 17, 2010 6:28 pm ]
I also bet your new fangled dizzy also has mechanical advance.
So-called `vacuum advance' is only a part throttle economy device. it has no other function. If you have a sporty cam with more than about 270° duration, it won't work anyway. :lol:
