camshaft end float
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67087
Author:  Goldbrocade_62 [ Thu Nov 18, 2010 10:13 am ]
Post subject:  camshaft end float
Just put a camshaft,new oil pump and new duplex timing sprockets how much end float should there be on it with, new sprocket on it I get 16 thou old one I get 6 thou I presume I will need to set new one up in my lathe and machine it down but is 6 thou right or should it be less makes it difficult for lining up sprockets
Author:  GT mowog [ Thu Nov 18, 2010 11:29 am ]
There is no presibed end float on the camshaft.
The lobes are ground (or should be!) such they they are not parallel to the shaft centre line but slightly tapered - all the same way - so the Cam actually thrusts in to the cam thrust plate (funny 'bout that!) as it rotates.
Author:  drmini in aust [ Thu Nov 18, 2010 4:15 pm ]
Did you replace the triangular thrust plate? They do wear, the coating is whitemetal.
Maybe it is a bit worn and someone machined the old sprocket to compensate.
Karcraft and Minis Plus both stock the plate.
I aim for about .005" end float when assembled on the cam.
Author:  Goldbrocade_62 [ Thu Nov 18, 2010 4:28 pm ]
Replaced that to I even put a very good old one on it comes up with the same amount of end play might just skim it on the lathe
Author:  drmini in aust [ Thu Nov 18, 2010 4:40 pm ]
Remember these `new' duplex timing sprockets are all aftermarket and made God knows where now. Probably made off a sample.
They would not be privy to a BMC/Leyland/Rover component drawing. :wink:
Author:  Goldbrocade_62 [ Thu Nov 18, 2010 7:28 pm ]
Thats what I thought will skim it tomorrow thanks for you help guys
