seifer wrote:
Hey Huys,
Ive spent a few days searching all this so dont jump all over me for asking.
My 71 Clubby is in need of a disc conversion which from what i can tell means changing over from my rubber uni's (thank buggery for that).
Ill be taking the engine out over the next few days to paint my engine bay and also engine so I figure I might do the diff change over whilst I am at it.
From what I have read all i need to change is the inner and outer axles?
If this is the case where do I need to/can I buy these from fairly cheaply?
Also what price should I pay for an 8.4 inch conversion kit, im thinking around 700 is fair?
Does any one have any diagrams of a mini diff or even instructions for changing the axles over?
Im located in Sydney if that is of any assistance.
Cheers guys,
No, the unis don't necessarily need to be changed out. The shafts are compatible with discs or drums. You only need the disc brakes themselves. The shafts will insert into the disc brake CVs the same as a drum brake CV. This means you can rethink if you want to change the inner unis out for another type, although this is not necessarily a bad idea if you have rubber joints.
Therefore, you just need the disc brake conversion kit. Nothing from the drum brake comes across except the steering arms. You will also need the flexible lines for a disc brake, they're slightly longer than drums.
So there will be the hub, caliper, drive flange, disc, CV, brake line, CV boots and tapered washer for each disc brake side, and you might as well get new ball joints as well.
Second hand disc brake setups might sell around 700, new are found for about the 1000 - 1300 mark.
