GT mowog wrote:
Hey tuff998, if you've got crabs you should get some medical attention! Nah, just kiddin'.........
Not unusual. They were never real good from the factory, most untouched minis I looked at crab. While it is fairly easy to get the rear toe in correct, from one side to the other, it actually needs to be set up using the centre line of the body to be correct and take the crabs away.
You can put shims in between the trailing arm bracket and the subframe on the RH side to reduce the toe in that it has.
But, if it has toe OUT on one side like mine did, with NO shims in, Houston we have a problem.
Fortunately some angle measurements and a bit of basic trigonometry allowed me to move the bracket hole forward and fix the problem.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
