how to set electric dizzy static timing https://www.ausmini.com/forums/viewtopic.php?f=2&t=67149 |
Author: | dodge [ Sun Nov 21, 2010 8:04 pm ] |
Post subject: | how to set electric dizzy static timing |
Just trying to set up my dizzy with a test light, i got the engine sitting at 5 deg BTDC and have fitted a test light to coil, if i rotate dizzy it light stays on , there is a short break point where no light is on but looks to me like the light is on for 1/4 turn of the dizzy what am i doing wrong |
Author: | 1275LS [ Sun Nov 21, 2010 8:07 pm ] |
I gather 5dbtdc is the manufacturers recommendation? The simonBBC one I have is 10dbtdc... |
Author: | GT mowog [ Sun Nov 21, 2010 8:12 pm ] |
Also sounds like you need to adjust yr point gap........ |
Author: | dodge [ Sun Nov 21, 2010 8:12 pm ] |
its just a starting point , new motor, just want to kick it in the guts ane run the cam in , i will adjust with strobe light once running |
Author: | 1275LS [ Sun Nov 21, 2010 8:13 pm ] |
GT mowog wrote: Also sounds like you need to adjust yr point gap........
Points on an electronic dizzy? Am I missing something? ![]() |
Author: | dodge [ Sun Nov 21, 2010 8:13 pm ] |
no points, its been converted by tony |
Author: | GT mowog [ Sun Nov 21, 2010 8:20 pm ] |
dodge wrote: no points, its been converted by tony
I just took it from your thread title 'electric' dizzy, I 'guessed' that you would have written 'electronic' if that was (and turns out is) the case. |
Author: | dodge [ Sun Nov 21, 2010 8:24 pm ] |
no worries my bad still want to know how to tell at what point the rotor and the cam/magnet actually shoot the power to the spark plug???? |
Author: | GT mowog [ Sun Nov 21, 2010 8:29 pm ] |
Not knowing what type of electronic set up it is, it would normally be - as you rotate the dizzy body clockwise - just as the lamp goes out. |
Author: | 1071 [ Sun Nov 21, 2010 8:31 pm ] |
With some electronically switched dizzies you can use a small radio (tranie ![]() Cheers, Ian |
Author: | drmini in aust [ Sun Nov 21, 2010 9:02 pm ] |
It's the same electronic module I'm using: You only need it nearly right to get it to start. Put motor on TDC, #1 firing. Mark the #1 plug lead's position on the dizzy body. Turn dizzy until rotor lines the mark up. Turn the body ~3mm clockwise. Refit the cap. Start it and use your timing light. |
Author: | dodge [ Sun Nov 21, 2010 9:05 pm ] |
http://www.ausmini.com/forums/viewtopic.php?t=53920 this type of set up |
Author: | dodge [ Sun Nov 21, 2010 9:25 pm ] |
the end of the rotor buton is very wide at what point does the rotor and cap trigger the connection |
Author: | TheMiniMan [ Sun Nov 21, 2010 10:00 pm ] |
Craig, do what the Doc said,,, put it "pointing" at number one & it`ll run then set it with the timing light |
Author: | dodge [ Mon Nov 22, 2010 6:53 pm ] |
did what the doc siad, started after 4 cranks, thanks for the quick and professional help. i have only ran at 2000 rmp so far , running in the cam. i will connect up the exhaust and take it for a blat to bed in the rings |
