It is currently Thu Aug 14, 2025 5:06 am
PostPosted: Mon Nov 22, 2010 8:55 am
I,ve just got my hands on an Avonbar 1 3/4 manifold , it is for a HIF44 but I assume a HS6 would bolt on the same, if it is for a HIF44 and if a HS6 fits I assume it will sit a little lower as the angle would suit a HIF44 so it clears the bonnet.
I have seen some flow rates for the Avonbar 1 3/4 manifold but they vary quite a bit , 104cfm to 119cfm , has anyone got a better idea ?
The HS6 will start with something leaner than a KP fixed needle , maybe a bit leaner than a BBZ . The 1275 auto will stay standard to start with , then I will move on to a head clean/ rebuild , Wade 240 cam with Isky lifters , one or two other bits and pieces
One thing I am keen to to find is a standard air box for a HS6 , rather than use a K&N cone filter I,d like to keep the engine bay fairly original which would include painting the Avonbar manifold black
PostPosted: Mon Nov 22, 2010 9:29 am
From memory you can only fit the standard air box to the HIF44, not to an HS6 as the bolt pattern for the filter/air horn is different, and air horns to suit the Mini filter are only available for the HIF44, not the HS6.
PostPosted: Mon Nov 22, 2010 3:20 pm
I,ll find out once I get more into it
I just used Simons SU needle chart and the RH fixed needle is a better needle than the BBZ recommended
PostPosted: Mon Nov 22, 2010 3:27 pm
can you post a few more pics up on the manifold? i just got the minispares HIF44/HIF6 manifold and it looks identical to your one, I have put it with a HIF6 on a pretty much stock 1275 and its running pretty well, bit rich but still sorting needles out, I will confirm what needle i am running and come back to you.
as for the CFM i have no idea.
Grant
100% Pure A Series Turbo
PostPosted: Mon Nov 22, 2010 3:35 pm
Grant
When I say I got my hands on, well not actually its being delivered so can't get you a better picture, as far as I know the difference between the MiniSpares and Avonbar is the the height of the dash pot screw/plug once fitted, the Avonbar is supposed to be lower to clear the bonnet with a HIF44 fitted
PostPosted: Mon Nov 22, 2010 3:47 pm
I've used both in the past, and don't remember a height issue with either. Seems to be the type of thing I'd remember!
PostPosted: Tue Nov 23, 2010 8:17 pm
No, there is no real height issue, its more how close to the firewall is the jet of the HS6 if its sits lower on a manifold for a HIF44, if you get what I mean
The RH fixed needle I mentioned is a lean needle for a Triumph Spitfire running twin HS6,s when compared on Simons chart to the recommended BBZ needle for a 1275 Mini the RH fixed needle is better
PostPosted: Tue Nov 23, 2010 9:03 pm
I just plotted it against an OA6 (which seems to always work well in an HS6/1275 combo)- it's the same gradient but a little richer than the OA6.
PostPosted: Tue Nov 23, 2010 9:07 pm
OA6 ? I,ll add that to the list , is that a fixed needle ?
Have you seen any flow rates for the Avonbar manifold ?
PostPosted: Tue Nov 23, 2010 9:11 pm
OA6 is what GR fits 1st up on dyno runs and 9/10 times it's perfect. It's a Healey 3000 needle I think and yes, it's fixed.
Nope not seen the Avonbar one but my new Minispares one looks same as your pic.
BTW I'm putting a 20mm thick alloy spacer on it, then I'll blend the spacer into the manifold entry for better flow.
I'll flow test it when finished. :P
PostPosted: Tue Nov 23, 2010 9:19 pm
:lol: You'll be finished before I am thats for sure !
20mm alloy spacer ? I,ll put that on the list as well
PostPosted: Tue Nov 23, 2010 9:21 pm
I've made the spacer 25mm thick, I'll machine it thinner if I have to (filter is only a Ramflo/Unifilter foam).
PostPosted: Wed Nov 24, 2010 5:01 pm
The standard air filter assembly might fit with a 20 mm spacer, but not much else will, I think. I've got a K&N cone filter on my 998 with a minipsport inlet which looks like yours. I originally left the spacer on, but I had to remove the sound insulation to fit it, and the original spacer is only 1/2" I think. Without the spacer it's still pretty tight.
PostPosted: Sun Dec 12, 2010 5:09 pm
Well, I now have the Avonbar 1 3/4 manifold , its very light , the casting is a bit rough but not as rough as some MiniSport manifolds I,ve seen , the seams will need a light sand , I really can't complain too much it only cost 22 pounds , I havn't got the motor in an engine bay to test the clearance for the jet/ needle to the firewall by the look of the angle it will be close, the photos are a mock up with the HS6 ( yes , it does need a clean and rebuild ), the manifold I might paint with KBS RustSeal in Grey
PostPosted: Sun Dec 12, 2010 6:15 pm
Looks much the same as my Minispares manifold.
Here it is with the 20mm spacer. I got it in there with it 25mm, but the jet was too close to the firewall, = no choke.
Working fine now 20mm thick.
Needle is an OA6, with yellow spring.
Users browsing this forum: No registered users and 233 guests
