Avonbar 1 3/4 manifold with HS6 setup https://www.ausmini.com/forums/viewtopic.php?f=2&t=67155 |
Page 1 of 2 |
Author: | Anto [ Mon Nov 22, 2010 9:29 am ] |
Post subject: | Re: Avonbar 1 3/4 manifold with HS6 setup |
74snail wrote: One thing I am keen to to find is a standard air box for a HS6 , rather than use a K&N cone filter I,d like to keep the engine bay fairly original which would include painting the Avonbar manifold black
. From memory you can only fit the standard air box to the HIF44, not to an HS6 as the bolt pattern for the filter/air horn is different, and air horns to suit the Mini filter are only available for the HIF44, not the HS6. |
Author: | 74snail [ Mon Nov 22, 2010 3:20 pm ] |
Anto wrote: 74snail wrote: One thing I am keen to to find is a standard air box for a HS6 , rather than use a K&N cone filter I,d like to keep the engine bay fairly original which would include painting the Avonbar manifold black . From memory you can only fit the standard air box to the HIF44, not to an HS6 as the bolt pattern for the filter/air horn is different, and air horns to suit the Mini filter are only available for the HIF44, not the HS6. I,ll find out once I get more into it I just used Simons SU needle chart and the RH fixed needle is a better needle than the BBZ recommended . |
Author: | Boostedmini [ Mon Nov 22, 2010 3:27 pm ] |
can you post a few more pics up on the manifold? i just got the minispares HIF44/HIF6 manifold and it looks identical to your one, I have put it with a HIF6 on a pretty much stock 1275 and its running pretty well, bit rich but still sorting needles out, I will confirm what needle i am running and come back to you. as for the CFM i have no idea. Grant |
Author: | 74snail [ Mon Nov 22, 2010 3:35 pm ] |
Boostedmini wrote: can you post a few more pics up on the manifold? i just got the minispares HIF44/HIF6 manifold and it looks identical to your one, I have put it with a HIF6 on a pretty much stock 1275 and its running pretty well, bit rich but still sorting needles out, I will confirm what needle i am running and come back to you.
as for the CFM i have no idea. Grant When I say I got my hands on, well not actually its being delivered so can't get you a better picture, as far as I know the difference between the MiniSpares and Avonbar is the the height of the dash pot screw/plug once fitted, the Avonbar is supposed to be lower to clear the bonnet with a HIF44 fitted . |
Author: | smac [ Mon Nov 22, 2010 3:47 pm ] |
I've used both in the past, and don't remember a height issue with either. Seems to be the type of thing I'd remember! |
Author: | 74snail [ Tue Nov 23, 2010 8:17 pm ] |
smac wrote: I've used both in the past, and don't remember a height issue with either. Seems to be the type of thing I'd remember!
No, there is no real height issue, its more how close to the firewall is the jet of the HS6 if its sits lower on a manifold for a HIF44, if you get what I mean The RH fixed needle I mentioned is a lean needle for a Triumph Spitfire running twin HS6,s when compared on Simons chart to the recommended BBZ needle for a 1275 Mini the RH fixed needle is better . |
Author: | drmini in aust [ Tue Nov 23, 2010 9:03 pm ] |
I just plotted it against an OA6 (which seems to always work well in an HS6/1275 combo)- it's the same gradient but a little richer than the OA6. |
Author: | 74snail [ Tue Nov 23, 2010 9:07 pm ] |
drmini in aust wrote: I just plotted it against an OA6 (which seems to always work well in an HS6/1275 combo)- it's the same gradient but a little richer than the OA6.
OA6 ? I,ll add that to the list , is that a fixed needle ? Have you seen any flow rates for the Avonbar manifold ? . |
Author: | drmini in aust [ Tue Nov 23, 2010 9:11 pm ] |
OA6 is what GR fits 1st up on dyno runs and 9/10 times it's perfect. It's a Healey 3000 needle I think and yes, it's fixed. Nope not seen the Avonbar one but my new Minispares one looks same as your pic. BTW I'm putting a 20mm thick alloy spacer on it, then I'll blend the spacer into the manifold entry for better flow. I'll flow test it when finished. ![]() |
Author: | 74snail [ Tue Nov 23, 2010 9:19 pm ] |
![]() 20mm alloy spacer ? I,ll put that on the list as well . |
Author: | drmini in aust [ Tue Nov 23, 2010 9:21 pm ] |
I've made the spacer 25mm thick, I'll machine it thinner if I have to (filter is only a Ramflo/Unifilter foam). |
Author: | Irish Yobbo [ Wed Nov 24, 2010 5:01 pm ] |
74snail wrote: :lol: You'll be finished before I am thats for sure !
20mm alloy spacer ? I,ll put that on the list as well . The standard air filter assembly might fit with a 20 mm spacer, but not much else will, I think. I've got a K&N cone filter on my 998 with a minipsport inlet which looks like yours. I originally left the spacer on, but I had to remove the sound insulation to fit it, and the original spacer is only 1/2" I think. Without the spacer it's still pretty tight. |
Author: | drmini in aust [ Sun Dec 12, 2010 6:15 pm ] |
Looks much the same as my Minispares manifold. Here it is with the 20mm spacer. I got it in there with it 25mm, but the jet was too close to the firewall, = no choke. Working fine now 20mm thick. Needle is an OA6, with yellow spring. |
