Engine breathing https://www.ausmini.com/forums/viewtopic.php?f=2&t=67191 |
Author: | Goldbrocade_62 [ Tue Nov 23, 2010 11:03 am ] |
Post subject: | Engine breathing |
I'm putting a maniflow twin su inlet manifold on the stroker it has no provisons to use S type pcv valve do I put in a fitting, convert to ccv or use a normal tappet cover with the breather on it |
Author: | simon k [ Tue Nov 23, 2010 12:31 pm ] |
I'd tap it for a PCV... but CCV would be easiest - I don't like venting to the engine bay cos it smells |
Author: | Goldbrocade_62 [ Tue Nov 23, 2010 1:07 pm ] |
It is there steel manifold it needs a fitting welding on |
Author: | winabbey [ Tue Nov 23, 2010 3:13 pm ] |
If the carbys have the breather inlet tubes on them why don't you just use CCV? The plastic Y piece is inexpensive, as is the rubber tube. |
