It is currently Fri Aug 01, 2025 11:26 pm
 Post subject: engine whine
PostPosted: Sun Nov 28, 2010 5:56 pm
ive only recently aquired this mini and was told it has a 1380 in it. it sure aint a std 1275 because its very quick so a 1380 would fit
but
i have a loud whine from the engine when im powering along. sounds like a supercharger. the whine softens when i back off the power but is still there. there is no whine when the clutch is in.
i'm not sure if theres some sort of straight cut gears in the box or i'm just looking at worn idler gear thrusts.
any ideas?
- '74 Clubman Ute project
PostPosted: Sun Nov 28, 2010 5:59 pm
If it's in ALL gears including 4th and varies with RPM in each gear I'd say it's probably got straight cut drop gears in it. :wink:
PostPosted: Sun Nov 28, 2010 6:03 pm
yes it is in all gears and does vary with revs.
now another question for you.
when its sitting in neutral just idling ive got a bad rattle up the front. the rattle disappears when i put my foot on the clutch.
any ideas?
PostPosted: Sun Nov 28, 2010 6:04 pm
Straight cut drop gear chatter :lol:
PostPosted: Sun Nov 28, 2010 6:08 pm
and now another question about the g/box.
if i change up gears quickely it ALWAYS crunches. every gear. but if i change up slowely it doesnt crunch. in any gear.
but
changing down gears is fine. doesnt matter how fast i change down or what gear i change to it wont crunch,
any ideas?
PostPosted: Sun Nov 28, 2010 6:22 pm
Whats the chances it a worn out gearbox with dodgy synchros and bearings?
PostPosted: Sun Nov 28, 2010 6:29 pm
Would the clutch throw out bearing be stuffed?
PostPosted: Sun Nov 28, 2010 6:34 pm
all the other g/boxes ive had with dodgy synchros, it would crunch when i change down gears as well as up gears.
i'm putting my money on a worn g/box but has anyone else had this problem?
PostPosted: Sun Nov 28, 2010 6:35 pm
Mods rock!
any ideas?
Well, it is English...
PostPosted: Sun Nov 28, 2010 7:03 pm
GT mowog wrote:
any ideas?
i prefer my engine whine to the whineing coming from the kitchen at dinner time
PostPosted: Sun Nov 28, 2010 9:24 pm
GT mowog wrote:
any ideas?
pop some cheese in the oil filler hole
PostPosted: Sun Nov 28, 2010 9:51 pm
simon k wrote:
GT mowog wrote:
any ideas?
That only works on French cars, and depends on the colour of the wine. Red, White or Rose?
