lights out
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67207
Author:  Muttley [ Tue Nov 23, 2010 11:28 pm ]
Post subject:  lights out
minimuts out driving in the new 1275LS beast tonight and the lights went out (almost predictable).
Fuses OK - even changed them.
Any thoughts on the source of the problem?
Author:  GT mowog [ Wed Nov 24, 2010 5:43 am ]
I have had a number of the Headlight / parker switches fail and without warning.
Author:  Convertible Mini [ Wed Nov 24, 2010 6:29 am ]
Post subject:  Lights fault
Check if the parkers still work, then see if you have an output on the blue wire to the dip switch then see if there is power coming out of the dip switch from the blue/red when on low beam and Blue/ white on high beam. If there is nothing coming out of the rocker switch you can carefully pull it apart and clean the contacts. But if after doing so the fault is cleared I would suggest fitting headlight relays to take the main headlight load away from the switches. And you will end up with better lights too.
Author:  Muttley [ Wed Nov 24, 2010 8:54 am ]
No tail lights or interior lights.
Engine still starts & have indicator lights.
Will get minimuts to work checking where the power is/isnt.
Author:  Convertible Mini [ Thu Nov 25, 2010 5:55 am ]
Post subject:  No lights
Check your Main power Fuse.
Author:  minimuts01 [ Thu Nov 25, 2010 6:49 pm ]
Post subject:  Re: No lights
That was the first thing we did.
Author:  1275LS [ Thu Nov 25, 2010 11:22 pm ]
My 1275LS was doing the same thing until recently. Check the 15 amp inline fuse on the middle of the firewall.
Also, the problem has disappeared since the relays were installed and as Tony says, the lights are now heaps better. No need for H4's.
Author:  minimuts01 [ Fri Nov 26, 2010 4:51 pm ]
interior light, brake lights and indicators work. no parkers or speedo surrounding light tho.
Author:  1275LS [ Fri Nov 26, 2010 8:12 pm ]
Those are the exact same symptoms mine had.
Fuse.
Relays.
Circuit board on cluster.
No more problems. :D
Author:  Muttley [ Sun Nov 28, 2010 9:54 pm ]
pulled light switch and cleaned up contacts - no change.
no in-line fuse (there is on the project clubman, but not the LS)
it has relays.
figuring minimuts might visit the auto-elecs tomorrow
(electricals not my thing)
