Fuel Tank removal https://www.ausmini.com/forums/viewtopic.php?f=2&t=67230 |
Author: | jester99 [ Thu Nov 25, 2010 8:07 am ] |
Post subject: | Fuel Tank removal |
hi everyone, am trying to remove the LH fuel tank from my 65 Deluxe and after wrestling with it for 3 hours last night, i need a little assistance ![]() i have removed the rubber bung from around the filler neck, fuel line disconnected, strap removed and the tank is moving around, but the drain plug is fouling on the floor and i cant get it past it. the drain plug is next to impossible to remove, the nut is rounded pretty bad from a previous attempt and as the pipe is quite long comming off it, it fouls on the floor and i cant seem to lift the tank high enough in the boot cavity to get it through. to get at the drain plug it looks like i may have to drop the rear subframe out of the car, and cut it off somehow. any tips? Jason |
Author: | Lockie91 [ Thu Nov 25, 2010 8:39 am ] |
Post subject: | Re: Fuel Tank removal |
jester99 wrote: hi everyone,
am trying to remove the LH fuel tank from my 65 Deluxe and after wrestling with it for 3 hours last night, i need a little assistance ![]() i have removed the rubber bung from around the filler neck, fuel line disconnected, strap removed and the tank is moving around, but the drain plug is fouling on the floor and i cant get it past it. the drain plug is next to impossible to remove, the nut is rounded pretty bad from a previous attempt and as the pipe is quite long comming off it, it fouls on the floor and i cant seem to lift the tank high enough in the boot cavity to get it through. to get at the drain plug it looks like i may have to drop the rear subframe out of the car, and cut it off somehow. any tips? Jason Hey Jason, From my previous times in taking my tanks out, you shouldn't have to take the plug out. It is a bit of a struggle sometimes, and it's sorta a juggling act, but its quite do-able. ![]() ![]() PM ABOUT TO BE SENT ![]() |
Author: | Lockie91 [ Thu Nov 25, 2010 8:44 am ] |
edit, i have a feeling there is something underneath like a rubber or bung thing that has to be pulled out to allow more movement... ![]() ![]() ![]() |
Author: | Goldbrocade_62 [ Thu Nov 25, 2010 9:59 am ] |
I've snapped the big long tube off before to make it easier |
Author: | 66S [ Thu Nov 25, 2010 10:18 am ] |
On my Mk1's, there is no way the tanks will come out unless you take out the drain tube. I made a special long socket, 1/2" AF single hex and I reach up behind the subframe. Al |
Author: | DTrain [ Thu Nov 25, 2010 6:08 pm ] |
i got a set of wire cutters and cut the drain plug in half. if i need to drain it i will put a tube over the whole thing so it wont matter |
Author: | drmini in aust [ Thu Nov 25, 2010 6:10 pm ] |
Next time mine is out it's getting a grub screw + Loctite put in it. If a drain is needed, how come the RH tanks don't have em.. ![]() |
Author: | Morris 1100 [ Thu Nov 25, 2010 6:15 pm ] |
drmini in aust wrote: If a drain is needed, how come the RH tanks don't have em..
![]() Because the fuel runs from the right tank to the drain in the left tank anyway. |
Author: | drmini in aust [ Thu Nov 25, 2010 6:17 pm ] |
Meh- I just plug the outlet with a kinked bit of hose. Or drain it first at the electric pump... |
