Gearbox Gaskets
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67273
Author:  kiwiinwgtn [ Fri Nov 26, 2010 8:55 pm ]
Post subject:  Gearbox Gaskets
I just went to stick my box on to the engine and went to trial fit the gasket on to the gear box.
Should the gasket allow clearance so the o-ring can be fitted mine dosn't of course.
or do you fit teh o-ring and then the gasket on top
Ta
Kiwiinwgtn
Author:  drmini in aust [ Fri Nov 26, 2010 8:58 pm ]
Fit the O-ring first then the gasket.
I do them upside down, with the gaskets on the block- it's easier to drop the box onto the motor than vice versa. And less chance the 1/2 moon front seal will get dislodged.
Author:  kiwiinwgtn [ Fri Nov 26, 2010 9:02 pm ]
so the gasket dosn't sit flat then ..due to it sitting on the o-ring
Author:  drmini in aust [ Fri Nov 26, 2010 9:31 pm ]
True. It does though, when the bolts are tightened.
I stick a smear of HMP grease in the hole for the O-ring to hold it in place so it doesn't fall out.
Author:  Drexxle [ Sat Nov 27, 2010 2:04 pm ]
some of those half moon seals can be a pain, the orange ones fit better but are harder to locate, the black ones seem to fit better but when everythings bolted together they never locate properley.
and dont lose the o ring, youll lose oil pressure which is bad.
