Pre- Veto to Verto https://www.ausmini.com/forums/viewtopic.php?f=2&t=67405 |
Author: | 1275LS [ Wed Dec 01, 2010 5:48 pm ] |
Post subject: | Pre- Veto to Verto |
Hi all. Further to my last post, GT mowog has suggested I consider changing to a verto clutch as my car is a road car only and sub 100hp. So the question is: has anyone done one of these conversions and does it give a lighter clutch pedal than a standard mini one. (If you haven't can you avoid posting please except for links to someone who has) The motor is a 12H series 1275. If anyone has a similar engine with a verto conversion on Brisbane northside I could test drive that would be even better. I am at Strathpine. Thanks in advance. |
Author: | miniobsessed [ Thu Dec 02, 2010 4:01 am ] |
I have not done a conversion from non-verto to verto but I have driven many minis with both types of clutch fitted. From my experience the verto clutch is much lighter to operate than the earlier non-verto type. |
Author: | Timbo [ Thu Dec 02, 2010 8:45 am ] |
You could get all the verto parts from one of the thousands of people who have done the conversion the other way. ![]() Another option is to fit a brake booster to the clutch. It may sound weird but it works well. Its good for people who don't have strong legs. Tim |
Author: | 1275LS [ Fri Dec 03, 2010 8:35 pm ] |
Simon K's input: "I wonder if you can't make your pedal lighter by checking and adjusting the diaphragm as per this article: http://www.minimania.com/web/DisplayID/ ... ticleV.cfm if the diaphragm isn't set up properly, your foot needs to compress the spring, which makes for a hard pedal. If it is set up properly, the spring is pre-compressed, which makes for a soft pedal, with significantly improved clamping pressure For reference, I have a supercharged 1275 with a standard clutch, and my 13 year old daughter drives it without needing to strain on the clutch cheers, Simon" |
Author: | GT mowog [ Fri Dec 03, 2010 9:18 pm ] |
1275LS wrote: Simon K's input:
"I wonder if you can't make your pedal lighter by checking and adjusting the diaphragm as per this article: http://www.minimania.com/web/DisplayID/ ... ticleV.cfm if the diaphragm isn't set up properly, your foot needs to compress the spring, which makes for a hard pedal. If it is set up properly, the spring is pre-compressed, which makes for a soft pedal, with significantly improved clamping pressure For reference, I have a supercharged 1275 with a standard clutch, and my 13 year old daughter drives it without needing to strain on the clutch cheers, Simon" Hmmmm.......did Simon also mention that his daughter is a champion althete too? |
Author: | simon k [ Fri Dec 03, 2010 11:36 pm ] |
GT mowog wrote: 1275LS wrote: Simon K's input: "I wonder if you can't make your pedal lighter by checking and adjusting the diaphragm as per this article: http://www.minimania.com/web/DisplayID/ ... ticleV.cfm if the diaphragm isn't set up properly, your foot needs to compress the spring, which makes for a hard pedal. If it is set up properly, the spring is pre-compressed, which makes for a soft pedal, with significantly improved clamping pressure For reference, I have a supercharged 1275 with a standard clutch, and my 13 year old daughter drives it without needing to strain on the clutch cheers, Simon" Hmmmm.......did Simon also mention that his daughter is a champion althete too? watch it... or she'll kick you! |
Author: | NG [ Sat Dec 04, 2010 10:31 am ] |
Yep it is a Shitttttt load lighter just do it you won't look back. I have a at up I can sell you as I have a new clutch and fly set up Only done 10ks as I updated my vert for a blower. I'm at boondall northside we have 2 rovers minis you can try the pedal on. |
Author: | Morris 1100 [ Sat Dec 04, 2010 11:12 am ] |
When I replaced the clutch in my Morris 1100 about two years ago I fitted a Cooper S clutch and pressure plate. Big mistake! The Cooper S diaphragm it a lot stiffer to push than the stock one. If you don't have a powerful motor and never get clutch slip just use a stock pressure plate. |
Author: | GT mowog [ Sat Dec 04, 2010 12:10 pm ] |
simon k wrote: GT mowog wrote: 1275LS wrote: Simon K's input: "I wonder if you can't make your pedal lighter by checking and adjusting the diaphragm as per this article: http://www.minimania.com/web/DisplayID/ ... ticleV.cfm if the diaphragm isn't set up properly, your foot needs to compress the spring, which makes for a hard pedal. If it is set up properly, the spring is pre-compressed, which makes for a soft pedal, with significantly improved clamping pressure For reference, I have a supercharged 1275 with a standard clutch, and my 13 year old daughter drives it without needing to strain on the clutch cheers, Simon" Hmmmm.......did Simon also mention that his daughter is a champion althete too? watch it... or she'll kick you! ![]() |
Author: | drmini in aust [ Sat Dec 04, 2010 6:35 pm ] |
Morris 1100 wrote: When I replaced the clutch in my Morris 1100 about two years ago I fitted a Cooper S clutch and pressure plate. Big mistake!
The Cooper S diaphragm it a lot stiffer to push than the stock one. If you don't have a powerful motor and never get clutch slip just use a stock pressure plate. If the diaphragm is set up flat on assembly an S one is pretty light, so is an orange dot one. They get heavy to push when the assembled height is too great due to flywheel and backplate wear. I dislike the engineering of the Verto, the flywheel is not attached to the crankshaft, but the diaphragm spring is. ![]() It is much heavier, and its only advantage? is a lighter pedal + less force on the crank thrust washers. |
