Tie Bar Bolt Removal
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67419
Author:  dtorreal [ Thu Dec 02, 2010 12:30 pm ]
Post subject:  Tie Bar Bolt Removal
Hey guys
I thought i would change my tie bar rubbers as they had perished. When removing the back nut attached to the lower control arm i hit the brake line behind the brake drum with the bolt head thus not allowing me to take the bolt out. Is this common? Am i missing a step somewhere?
Thanks
Author:  michaelb [ Thu Dec 02, 2010 12:36 pm ]
You may need to undo the lower ball joint so as to gain the clearance to remove the bolt.
Dont be tempted to replace the bolt up from the bottom-up as I did once and the nut worked loose and the bolt fell out at 100km/h and the mini wanted to do a hard left turn. :shock:
Luckily I was holding onto the steering wheel with both hands. :)
Author:  simon k [ Thu Dec 02, 2010 12:44 pm ]
you might find you can get it out if you jack up the hub - put your jack under the ball joint
Author:  dtorreal [ Thu Dec 02, 2010 1:48 pm ]
Post subject:  got it
Thanks guys. With a lot of subtle pressure i used a combination of both your advises and it had enough clearance.
Thanks
Author:  GT mowog [ Thu Dec 02, 2010 1:55 pm ]
The bolts are put in that way so even if the nut come off, the bolt is un-like to come out (but still can :roll: ).
Author:  Hunter2 [ Mon Dec 06, 2010 3:43 am ]
Good you replaced them. A 50 cent service job I do once a year on the Mini.
