Is this inner race knackered?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=67446
Author:  Wombat [ Fri Dec 03, 2010 5:36 pm ]
Post subject:  Is this inner race knackered?
This is the worse - three other surfaces have marks but the 'skin' is not broken - one surface has a mark and a small pit
Use or not to use?
Author:  GT mowog [ Fri Dec 03, 2010 6:17 pm ]
If you were caught out in the desert with a broken CV, that one would be gold......
However since I think your at home, why not do yourself a favour and chuck that one in the bin.......
Author:  Wombat [ Fri Dec 03, 2010 7:24 pm ]
I haven't checked the other side - but do you normally replace both as a pair or only if damaged?
Author:  GT mowog [ Fri Dec 03, 2010 7:29 pm ]
Complete CV joints either outright or exchange are not very expensive these days, although I have a strong preferance for new joints. Some of the re-built ones are not much better than the ones you take out.
Generally, I would only replace the one side if that is knackered, although, if I'm doing a ground up resto, then I do everything so it all starts off on the same foot. Depends too on how much $$$$ you wish to invest in your project and how much use it will see.
Author:  Wombat [ Fri Dec 03, 2010 7:51 pm ]
$55 each at Karcraft - may as well do both
