It is currently Tue Aug 12, 2025 2:37 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
PostPosted: Thu Dec 02, 2010 10:41 pm
right? :? :shock: :lol:
PostPosted: Thu Dec 02, 2010 10:50 pm
Some late nights coming up! Can't even use the piston as an ashtray! :shock:
PostPosted: Thu Dec 02, 2010 10:56 pm
that`s only one cyl down,,, there`s 3 more spare :-)
PostPosted: Thu Dec 02, 2010 11:56 pm
Hmmm.. tasty.... I have an EJ20 sitting here that looks like that :P
Dare I ask what happened Simon? :)
PostPosted: Fri Dec 03, 2010 12:01 am
pretty obvious phatty... valve stem breakage, head of valve pops off & smashes everything inside the cyl, puts hole in piston,,, lots of smoke & no compression,,, remove cyl head & photos show results :-)
PostPosted: Fri Dec 03, 2010 1:46 am
ouch,
is the bore ok?
PostPosted: Fri Dec 03, 2010 6:18 am
Give Ash some flowers Nick .
I hope that isn't your mini simon!
PostPosted: Fri Dec 03, 2010 6:22 am
Mods rock!
Sure is!
If you don't collect a few trophies along the way, your not trying.
That's a bugga for ya, Simon :x
PostPosted: Fri Dec 03, 2010 8:05 am
Jeez, how long was it running after the valve head broke off?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
 Post subject: It broke.
PostPosted: Fri Dec 03, 2010 8:52 am
That would have been noisy ! And it would have been spitting oil out of every orifice too. Did you try revving it to make the noise go away.... WRONG....
"Let us remove your "SHORTS"
PostPosted: Fri Dec 03, 2010 9:29 am
I'd made a wrong turn, so did a U turn and had just dropped it into 4th gear when it let go. It sucks because I was on my way to an event, not even competing!
I expected something to break soon, but not this... and it's my good Cooper S head too :( I didn't want to use it, but the one I'd planned to use wasn't ready
Phat kat wrote:
what happened?
the seat insert would have let go first, jammed the valve down, then the piston smashed into it which broke it off and then it just rattled around a bit. The seat is nowhere to be seen, must have been squashed and gone down the exhaust
Timbo and Convertible wrote:
how long was it running? would have been noisy!
didn't make a lot of noise, just a bit of a pop and the engine died... no smoke, no rattling - very unexciting
mini13 wrote:
bore OK?
not really, there are little dings in it, the spots you can see in the 3rd photo. It should bore OK to the next size up (+.060")
yeah, sh!t happens... I just need a Corolla or something to run around in so I don't have to drive my mini so much
PostPosted: Fri Dec 03, 2010 9:34 am
bad luck simon
PostPosted: Fri Dec 03, 2010 10:04 am
Wash your mouth out - those are evil thoughts! :x
Minis are made to be driven (and then repaired).
Can hardly wait until mine is back on the road again.
PostPosted: Fri Dec 03, 2010 10:08 am
Good call! Get a bubble for it!
PostPosted: Fri Dec 03, 2010 10:39 am
nah - I'll leave it out in the rain by the side of a dirt road :lol:
Users browsing this forum: timmy201 and 235 guests
