It is currently Sun Aug 17, 2025 7:46 pm
 Post subject: Rod Change to Remote
PostPosted: Sat Dec 04, 2010 3:57 pm
what`s involded in converting from rod change to remote ?
is it worthwhile ?
many thanks
jayson
 Post subject: Changing gearbox.
PostPosted: Sat Dec 04, 2010 6:03 pm
It will involve changing the whole gearbox over and even Axles Brackets Drilling holes. and lots more. Is it worth it?
Your Call. Not something you do for the fun of it.
"Let us remove your "SHORTS"
PostPosted: Sat Dec 04, 2010 6:13 pm
It's not hard at all, as far as fitting to the car goes.
If you use your pot joints (swap your diff into the remote box) the only mod needed is drill 3x 5/16"dia holes in the tunnel to mount the rear remote bracket.
When done you can throw away that silly cylinder head steady bar and bracket that rips holes in the firewall- it's not needed. :P
PostPosted: Sat Dec 04, 2010 8:22 pm
Supercharged
its not worthwhile
PostPosted: Sat Dec 04, 2010 9:30 pm
I prefer remote, but a good rod change is as good as any, note the drmini ":P"... ;)
Jacob
PostPosted: Sun Dec 05, 2010 8:23 am
thanks all,i think i`ll just stick to the rod change.
jayson
PostPosted: Sun Dec 05, 2010 8:28 am
Why were you thinking of changing?
PostPosted: Sun Dec 05, 2010 8:31 am
just a silly idea that popped into my head
PostPosted: Sun Dec 05, 2010 12:16 pm
Supercharged
if you're looking for an improvement, get some new bushes for it.
PostPosted: Sun Dec 05, 2010 9:20 pm
Yeah and if you really want, get a quickshift kit. There are ones (I think they are minispares... I'll check tomorrow) that aren't dear at all and they take about 20min to install with your left hand.
The one I'm reffering to just changes the fulcrum in the shifter so that the throw between gears is shorter, and unlike some on the market, it doesn't push the gear stick over to one side causing the selector forks to rub and wear out on the sides of the synco hubs.
Users browsing this forum: No registered users and 303 guests
